Blade 130 X - 3D Settings
- Tom Z
26 Jan 2014 17:06 - 15 Feb 2014 23:33 #19174
by Tom Z
Normal: 0% 40% 60% 68% 75%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Blade 130 X - 3D Settings was created by Tom Z
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 36 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 36-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 36 instead.
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:33 by Tom Z.
- Tom Z
26 Jan 2014 19:40 - 26 Jan 2014 19:56 #19198
by Tom Z
Replied by Tom Z on topic Blade 130 X - 3D Settings
I forgot to add my custom GUI. I just added it and re-uploaded the models.
If you downloaded the file before I posted this you should download the model again as that model will use the default GUI on your transmitter and not my custom GUI which works on all the transmitters, has all the switch icons assigned to them, and has a custom layout for your home screen.
Last edit: 26 Jan 2014 19:56 by Tom Z.
- Torch
05 Jun 2014 01:52 #23913
by Torch
Replied by Torch on topic Blade 130 X - 3D Settings
Devo 7E can't bind to your Blade 130x models (Deviation firmware 4). With my Orange T-6 or Dx6-i I would hold the trainer switch and turn on Radio to bind to the DSM2/X aircraft. How do bind to now?
- Torch
05 Jun 2014 03:21 #23914
by Torch
Never mind figured it out. Need to press ENT on BIND tab. Found it on rcgroup devo forum 1236 posting.
Time to create page: 0.185 seconds
Model Configs
- Blade 130 X - 3D Settings
