Walkera G400 GPS
- Tom Z
29 Jan 2014 01:44 - 30 Apr 2014 15:21 #19356
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: -2* negative pitch. Zero degrees pitch at mid stick.
Mix Switch
Switch Position 0: Manual Mode
Switch Position 1: Position Hold Mode
Switch Position 2: One Key Go Home
*Take off in Manual Mode
Gear Switch
Switch Position 0: Working Mode
Switch Position 1: Adjust Mode
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP -10%
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Walkera G400 GPS was created by Tom Z
- GPS Functions on the Mix Switch.
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
Model 38 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Throttle Curve
Pitch Curve
Mix Switch
Gear Switch
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:21 by Tom Z.
- aerocarv
14 Dec 2021 14:05 #77625
by aerocarv
Replied by aerocarv on topic Walkera G400 GPS
Tom, Hope you check your postings, even now in 2021.
I have several G400's. All are setup for "normal" or "beginner" flight. The stunt 1 and 2 are setup as "Normal" conditions.
The use of the "MIX" switch ONLY for both flight mode changes, gyro settings and Normal, position hold and RTH makes NO SENSE. It seems to me that there MUST be a second transmitter switch to do all this.
Advise. Hope to hear from you. Ed
Time to create page: 0.380 seconds
Model Configs
- Walkera G400 GPS
