Nine Eagles Solo Pro 125 - Beginner Settings
- Tom Z
04 Feb 2014 23:28 - 15 Feb 2014 23:39 #19841
by Tom Z
Nine Eagles Solo Pro 125 - Beginner Settings was created by Tom Z
Nine Eagles Solo Pro 125 (125A)
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
- No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
- Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike. - 7 Point Throttle and Pitch Curves
- Low dual rates and positive expo to tame the heli down
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Channels=6
- Protocol=J6Pro
- No Fixed ID
If you fly outside in wind use ST-1 or ST-2 which have full pitch curves which can pull the heli down in wind.
Model 45 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:39 by Tom Z.
Time to create page: 0.213 seconds
Model Configs
- Nine Eagles Solo Pro 125 - Beginner Settings
