Nine Eagles Solo Pro 125 - Standard Settings
04 Feb 2014 23:29 - 15 Feb 2014 23:39 #19842 by Tom Z
Nine Eagles Solo Pro 125 (125A)
  • Low dual rates and positive expo to tame the heli down
  • Throttle hold on the RUDD D/R switch
  • 7 Point Throttle and Pitch Curves
  • TX Power=100mW
  • Channels=6
  • Protocol=J6Pro
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 46 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gyro Gain - These are the values I used then converted them to the deviation values.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Last edit: 15 Feb 2014 23:39 by Tom Z.
11 Feb 2016 11:59 #42997 by jm2cau
I do not understand why it is not stable with this file it turns left
thank you for helping me
Time to create page: 0.501 seconds
