Flip FPV Quadcopter
- Tom Z
18 Feb 2014 06:15 - 18 Feb 2014 15:59 #20512
by Tom Z
Flip FPV Quadcopter was created by Tom Z
This model was made by Rambosmurf which sent me the model.
I converted it to the V4 firmware and added my custom GUI.
Edit: 2-18-2014
The model has been updated. The new model name is Model1_FlipFPV_V2
The Quad is running the Crius AIOP V2 Board with GPS and MegapiratesNG software.
Flight Modes when using Mission Planner are:
FMode 0 = Stab - Self Correcting Flight
FMode 1 = Acro - Full 3D Controls
FMode 2 = Loiter - GPS Lock and Altitude Hold
Mix 0 = Nothing - Stab Mode Default
Mix 1 = Alt Hold - Non Gps Hold
Mix 2 = RTL - Return to Launch
Gear = Land - Lands at present location
Channel 6 is connected to Aux 5 which can be used to do tuning via Mission planner. Channel 7 is set-up for extra use of servo for camera gimbals or other options.
The model is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
* The model will not work for deviation firmware v2.1 or v3.
Edit: 2-18-2014
Last edit: 18 Feb 2014 15:59 by Tom Z.
- Rambosmurf
18 Feb 2014 13:42 #20521
by Rambosmurf
Replied by Rambosmurf on topic Flip FPV Quadcopter
Thank you for the conversion. I appreciate it.
RS
RS
- satishkbg
22 Nov 2014 18:52 #26521
by satishkbg
Replied by satishkbg on topic Flip FPV Quadcopter
Thanks for a great config, I'm using the same with my devo10.
Actually getting started with my quad with MegapirateNG.
I have done the radio calib on Mission Planner. I have also done the ESC calib.
I need to know what other calibrations is necessary to start flying, for example for different Flight Modes you have here. It'll be of great help if you could share the steps.
Time to create page: 0.601 seconds
Model Configs
- Flip FPV Quadcopter
