Blade Nano CPX/mCPX/130X - 3 Difficulty Modes
- Tom Z
- Topic Author
01 May 2014 04:33 - 01 May 2014 13:26 #22818
by Tom Z
Blade Nano CPX/mCPX/130X - 3 Difficulty Modes was created by Tom Z
I made this model based off my other Blade models.
It has 3 difficulty modes: Beginner, Standard, 3D. The difficulty modes are controlled with the Flight Mode Switch.
This model is for the Blade Nano CPX/mCPX BL.
There are models below this post for the Blade 130X and Blade mCPX V1/V2.
Normal - Beginner Settings
No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
D/R = 50% EXP +30%
ST-1 - Standard Settings
-3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
D/R = 70% EXP +30%
ST-2 - 3D Settings
Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
D/R = 125% EXP LIN
Model 49 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
ST-1: -3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
ST-2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
DR/EXPO
DR/EXPO is controlled with the Flight Mode Switch.
Normal: Beginner Settings
ELEV D/R = 50% EXP +30%
AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
ST-1: Standard Settings
ELEV D/R = 70% EXP +30%
AILE D/R = 70% EXP +30%
ST-2: 3D Settings
ELEV D/R = 125% EXP LIN
AILE D/R = 125% EXP LIN
D/R = 50% EXP +30%
D/R = 70% EXP +30%
ST-2 - 3D Settings
D/R = 125% EXP LIN
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Pitch Curve
DR/EXPO
ST-2: 3D Settings
Last edit: 01 May 2014 13:26 by Tom Z.
- Tom Z
- Topic Author
01 May 2014 04:34 - 01 May 2014 04:47 #22819
by Tom Z
Replied by Tom Z on topic Blade 130X - 3 Difficulty Modes
This model is for the Blade 130X.
Model 50 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Last edit: 01 May 2014 04:47 by Tom Z.
- Tom Z
- Topic Author
01 May 2014 04:34 - 01 May 2014 04:47 #22820
by Tom Z
Replied by Tom Z on topic Blade mCPX - 3 Difficulty Modes
This model is for the Blade mCPX V1/V2.
Model 51 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
- Fer
24 Apr 2015 22:16 #31583
by Fer
Replied by Fer on topic Blade mCPX - 3 Difficulty Modes
I only received my DEVO10 yesterday. Thank you for the files, i was able to bind my two mcpx/v1/v2 i have. I had tryed numerous times to bind them before, but i failed. Only after i downloaded these files i was able to bind. Only that i had to change DSMX to DSM2 to bind them.
I have also downloaded the file for the 130X, but i will bind it later. For the time beeing i want to "study" what you have written in the files and try to adjust the values to better much my two mcpxs. This look like a hard task for me, because i have never had a DEVO tx before.
- Home
- Blade Nano CPX/mCPX/130X - 3 Difficulty Modes
