T-rex 450 pro DFC with DSM2
25 Jul 2014 06:07 #24787 by suchyjar
T-rex 450 pro DFC with DSM2 was created by suchyjar
Hi, I would like to ask if someone you do not .ini file for T-rex 450 for DFC. I use it with satellite DSM2.
Thanks for any reply
07 Aug 2014 12:33 #25074 by suchyjar
Replied by suchyjar on topic T-rex 450 pro DFC with DSM2
Do not say, nobady fly with trex 450 for dfc to DSM2/x?
07 Aug 2014 14:08 #25075 by tmcg
Replied by tmcg on topic T-rex 450 pro DFC with DSM2
I have Trex 250 pro dfc with microbeast and dsmx sat. I just used the standard gui (instead of advanced), set new model to DSMX 8 channels and went through all the individual settings. The channels were already in correct order. I prefered this to copying an ini because I can see all the individual settings available to me. I would be happy to send you the standard gui ini that I have but I don't have the idle-up 3D (flight mode 3rd position) configured properly yet because I'm still working on my 2D flight. And the gyro percentages are probably different for 3GX than for microbeast.
07 Aug 2014 21:00 - 07 Aug 2014 21:01 #25086 by billmester
Replied by billmester on topic T-rex 450 pro DFC with DSM2
File Attachment:
File Name: model2.ini
File Size:4 KB
I have an .ini for my Align 450 pro DFC 3GX with dual DSMX sats for DEVO10.
Very old file, I have changed the heli since, I found this in my archives. Please check before use - any questions, just ask.
Use at your own risk :)
bm
Last edit: 07 Aug 2014 21:01 by billmester.
08 Aug 2014 01:00 - 08 Aug 2014 01:07 #25088 by dat
Replied by dat on topic T-rex 450 pro DFC with DSM2
here,the model is 450 pro v2 type with dsm2 and a ZYX-S gyro and plus a sat i used it on my DEVO 12S before.
but , but , i sincerely to recommend to you , resetup your heli from a new model by you yourself. you know why ? because every gyro always must to do a setup when you first use.
Last edit: 08 Aug 2014 01:07 by dat.
11 Aug 2014 13:30 #25140 by suchyjar
3GX I set again. I found this forum some ini files, although it works, but I do not understand at all settings, it's all weird. Thank you for the files, I'll try and give you an answer.
15 Aug 2014 03:05 #25199 by Ferdey
Replied by Ferdey on topic T-rex 450 pro DFC with DSM2
billmester, thank you for that file! I have been struggling to get my swash mixing working on my 450L/3GX and that file showed me how to do it. Phew!
Time to create page: 0.028 seconds
