Binding problem
- baekelal
18 Aug 2014 20:04 #25269
by baekelal
Binding problem was created by baekelal
Dear,
I can't bind my devo 10 tx with deviation 4.0.1 to my walkera qr x350 pro. I use protocol devo but nothing happens. Should i start first the binding proces and then connect the battery off the quad ? Btw i also tried with deviation 3.00 same problem.
I also reversed the firmware to stock walkere firmware but there everything in the menu shows up as "YYYYYYYYYYY". The english language is selected tho.
greetings Alex
greetings Alex
18 Aug 2014 20:49 #25271
Replied by FDR on topic Binding problem
Remove the fixed id on the model setup page...
- Blayd
18 Aug 2014 22:15 #25273
by Blayd
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
Replied by Blayd on topic Binding problem
Yep.
Touch the Fixed ID numbers, delete the ID numbers in the next page.. it will then say "NONE" you'll have to hit the "bind" tab when you plug in the quad, Deviation will take a few seconds counting down then try to bind to your quad.
You can then set a fixed ID for the quad by touching the numbers again, entering your ID that you want, and the Tx will enter the ID as a fixed ID for the quad model. If you had a fixed ID in the Rx of the quad, you need to clear it or Deviation wont bind to it. Then reset it, I believe.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Time to create page: 1.006 seconds
Model Configs
- Binding problem
