Blade 180CFX with Devo8S
30 Oct 2014 21:00 #26231 by Joshua
Blade 180CFX with Devo8S was created by Joshua
My setup for the new Blade 180-CFX
File Attachment:
File Name: model3.ini
File Size:8 KB
ciao, Bernd
02 Nov 2014 18:48 #26262 by skippajack
Replied by skippajack on topic Blade 180CFX with Devo8S
Awesome, I am new to deviation, I am wondering if this will work for the devo 10.
Thanks for sharing!
03 Nov 2014 11:26 #26274 by Joshua
Replied by Joshua on topic Blade 180CFX with Devo8S
skippajack wrote: Awesome, I am new to deviation, I am wondering if this will work for the devo 10.
Thanks for sharing!
I think, it will work for Devo 10- ;)
04 Nov 2014 04:05 #26279 by itsmillertime
Replied by itsmillertime on topic Blade 180CFX with Devo8S
Have you figured out how to assign the bind "switch" to aux 2 in order to access the servo trim menu? How about getting into the cyclic/ rudder gain menu?
04 Nov 2014 09:40 - 04 Nov 2014 09:45 #26281 by Joshua
itsmillertime wrote: Have you figured out how to assign the bind "switch" to aux 2 in order to access the servo trim menu? How about getting into the cyclic/ rudder gain menu?
I am working on that. :P
That is what i have until now:
http://www.helifreak.com/showthread.php?t=661770
"On your Transmitter, hold the sticks as follows:
Left Stick: Bottom LEFT corner
Right Stick: Bottom RIGHT corner
Then push the bind/trainer switch until the swash moves.
1. You should have heard the swash move (servos move) and the gyro should now be disabled (can move heli around, servos/swash should not move). The servos have now been driven to their middle or reference positions.
2. Ensure each of the servo arms are as close to 90 degrees as possible by adjusting the servo arm itself (remove and re-install). The angle will not be a perfect 90° yet at this stage.
3. Then we can fine-tune each servo to get them as close to 90 degrees as possible. Give Right Aileron to select servo (it will "twitch").
4. Use Elevator (Right stick up and down) to adjust centering of servo to get a "perfect" 90 on each servo. Use Right Aileron to move to the next servo and repeat the process.
5. Once you are complete and have all the servos as close to 90 degrees as possible, adjust the cyclic/swashplate linkage rods to get the swashplate level. Do this by carefully popping the link off the swash and turning as required to get the swash perfectly level on all three linkage rods (level at this point is parallel with the bearing block below the swash).
Last edit: 04 Nov 2014 09:45 by Joshua. Reason: Added Link
05 Nov 2014 22:00 #26293 by Hexperience
Replied by Hexperience on topic Blade 180CFX with Devo8S
AUX2 is just channel 7. Make channel 7 simple,source TRN1 (or TRN0 and reverse it.) Just so that channel 7 is +100 when NOT pressed and -100 when pressed.
I did it on my devo12. However, the version of Deviation I'm running (haven't been here in a long time) does NOT show the correct information in the telemetry for the advanced gyro settings. I was able to level the swash though.
07 Nov 2014 19:11 #26311 by itsmillertime
Curious if the changes you made in the servo centering menu actually saved. Reports are that they aren't saved after a power cycle.
13 Nov 2014 17:09 - 13 Nov 2014 17:10 #26391 by Joshua
itsmillertime wrote: Curious if the changes you made in the servo centering menu actually saved. Reports are that they aren't saved after a power cycle.
Software update is availiable for that problem: ;)
http://www.helifreak.com/showthread.php?t=664098
Last edit: 13 Nov 2014 17:10 by Joshua.
14 Nov 2014 00:27 #26397 by Sol2014
Replied by Sol2014 on topic Blade 180CFX with Devo8S
does it work with devo 7e?
14 Nov 2014 04:08 #26398 by itsmillertime
I noticed that. Unfortunately though, my 180 is in the mail heading back to Horizon.
helifreak.com/showthread.php?t=663798
I compared my radio settings to yours but didn't see anything too different.
14 Nov 2014 13:35 #26402 by Joshua
Sol2014 wrote: does it work with devo 7e?
Didn't try it, because i have no 7e, but i think it will work. ;)
14 Nov 2014 21:03 #26408 by Hexperience
I know this has been answered, but you are correct. The settings did NOT save until I put the firmware update on the 180 cfx.
If anyone else has a 180 cfx can you tell me what you get in your telemetry window when/IF you go into the PID menu? I see FadesA go from 1 to 7 as I move through the menu, but I never see any other value change so I don't know what values they are at.
Please DON'T do it if you are uncomfortable, you could mess up the PIDs and cause your heli harm. I simply went through the menu and moved the rubber stick to the right to set back to default and hope that I didn't change anything by accident.
17 Nov 2014 22:21 #26447 by itsmillertime
Even if you do mess up the default PID settings you can revert by simply moving the rudder. HH is sending me a new one so I'll play with telemetry settings once I get it. All I have so far is telemetry enabled on dsmx protocol. Not sure what I need to enable yet.
19 Nov 2014 20:13 #26461 by itsmillertime
Still don't have my 180 but I found some info that might be useful. On Spektrums "flight log" telemetry screen you have:
A - Antennae fades on internal antennae A
B - Antennae fades on internal antennae B
L - Antennae fades on the left external antennae
R - Antennae fades on the right external antennae
F - Frame loss
H - Holds
Now to figure out to to display this info in Deviation...
22 Nov 2014 10:35 #26513 by itsmillertime
I seem to have a control issue. Anyone seen this before?
I've attached my model file as well.
22 Nov 2014 10:58 #26515 by itsmillertime
Turned off telemetry, rebound and all is well. Too bad, was hoping to be able to view gain adjustment via tx.
05 Dec 2014 18:35 #26785 by sourdiesel
Replied by sourdiesel on topic Blade 180CFX with Devo8S
Thank you for the config - I just maidened the 180 cfx on my white devo 10.did some sweet side flips and inverted hover. I figured out throttle hold and how to change the governed speed with fmode, also the expo/Dr, what effect does the gear switch have ? I don't wanna flip it mid flight and have something happen that I didn't want. Also any other switches I missed would be great . I'm completely new at this and appreciate the help.
31 Dec 2014 07:24 - 31 Dec 2014 07:26 #27371 by itsmillertime
Telemetry is working and gains can now be adjusted. Some weird things displayed like 655V but it does what I need it to do.
Last edit: 31 Dec 2014 07:26 by itsmillertime.
01 Jan 2015 17:01 - 01 Jan 2015 17:04 #27401 by fredolabidouille
Replied by fredolabidouille on topic Blade 180CFX with Devo8S
Hi guys :)
I'm about to buy this 180CFX and run it with my devo8s...
@itsmillertime, that happens between "control issue" and "telemetry working" ?
does the file you attached before runs (control issue was just a "bug" that you fix when rebind) or did you change some settings ? (so can you chare the new file, please)
and what version of deviation do you use ?
thanks ;)
Last edit: 01 Jan 2015 17:04 by fredolabidouille.
03 Jan 2015 08:04 #27430 by itsmillertime
Version 4.0.1
Originally used dsmx 7 channels when the control issue happened. Turned off telelmetry and rebound to solve it. Then I changed channels to 8 and turned telemetry back on and everything works as it should.
Time to create page: 0.188 seconds
