Juncheng 3015-1 / 3015-2
09 Oct 2015 13:42 #38651 by IKKI
Juncheng 3015-1 / 3015-2 was created by IKKI
Thank Goebish that allowed me to best use these beautiful micro quadcopters, I am attaching my ini files for DEVO 7E configured to switch 3x2
Here's a test version for Devo 7e:
www.dropbox.com/s/bj3ey2q0loy1t7k/deviat...0.1-ddc8b89.zip?dl=0
Source code:
bitbucket.org/goebish/deviationtx/branch/protocol_q282#diff
It has CX10 Green, Blue-A, WLToys Q282 (thanks hexfet), DM007, JC3015-1, JC3015-2 and MK33041 format options.
Channel 5 controls rate (except on Q282: controls lights)
Channel 6 controls flips (double flips if >50 on JC3015-2)
Channel 7 controls picture snapshot (except on JC3015-1: controls lights)
Channel 8 controls video recording (requires toggle to start/stop on some models)
Channel 9 controls headless
Channel 10 controls RTH
17 Oct 2015 18:36 #38978 by Michael Thompson
Replied by Michael Thompson on topic Juncheng 3015-1 / 3015-2
Thank you for this!
28 Nov 2015 02:54 - 28 Nov 2015 22:23 #40454 by Multirotor Go
Replied by Multirotor Go on topic Juncheng 3015-1 / 3015-2
Hello
I successfully bind juncheng with devo 7e reversed elevator and aileron and is working fine but the rates are super low how I get the maximum rates? Up there says something about channel 5 but I have no idea what I have to do with that info, how I change the rates? Thanks
Last edit: 28 Nov 2015 22:23 by Multirotor Go.
28 Mar 2016 09:52 #45330 by BobMarley
Replied by BobMarley on topic Juncheng 3015-1 / 3015-2
Hi all! First post here for me. Anyone got a model.ini for JunCheng 3015-2 & Devo 7e where it is possible to switch the lights on and off and maybe the quad is directly on high rates after binding?
My Devo has only the two stock switches atm...
Got two ini files. One with lights permanent on and one with lights off. Cant find a file on Deviationtx forum for Devo7e with only two switches. Thanks for help!
29 Mar 2016 07:31 #45372 by Podflyer
Replied by Podflyer on topic Juncheng 3015-1 / 3015-2
I have the same issues with it being slow, any advice?
29 Mar 2016 18:08 #45392 by BobMarley
Change the Rates works for me with both ini files with one of the two switches hold or fmod... Pretty good rates and much much better then with stock transmitter!
07 Apr 2016 00:33 #45986 by kenstogie
Replied by kenstogie on topic Juncheng 3015-1 / 3015-2
i too have the same problem like its on low rates.....any advice?
27 May 2016 20:44 #49398 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Juncheng 3015-1 / 3015-2
Mine doesn't bind to the cx-10 protocol or any of its sub options.I have the red board it flys great but will probably fly awesome with my devo.Does anyone know if there's another deviated protocol to fly the red board jc-3015,all feedback is greatly appreciated.God bless.
28 May 2016 13:31 #49428 by IKKI
Replied by IKKI on topic Juncheng 3015-1 / 3015-2
kenstogie wrote: i too have the same problem like its on low rates.....any advice?
My last ini file
28 May 2016 16:25 #49439 by C0ckpitvue 777
Thanks Ikki but this protocol doesn't bind with the red board I have.
08 Jun 2016 23:51 #50217 by fbmmfsob
Replied by fbmmfsob on topic Juncheng 3015-1 / 3015-2
I had the same problem with my new 3015-2 so I chose the 3015-1 model instead and everything works great. It's fast and has great pitch, one of my favorites now, just ordered 2 more. I was bummed up until I figured this out. I'm using a Devo 7e and the switches are active for dual rates and flips, I think. I hope this helps out.
23 Jun 2016 01:34 #50966 by C0ckpitvue 777
Does anyone have a model ini for the Juncheng 3015-2 for the devo10 they care to share.I tried this ini with the devo10 but it doesn't let me yaw.All help is greatly appreciated.
name=CX-10 BLUE BOARD
mixermode=Advanced
[radio]
protocol=CX10
num_channels=5
fixed_id=123456
tx_power=150mW
[protocol_opts]
Format=JC3015-2
[channel1]
template=simple
[mixer]
src=AIL
dest=Ch1
scalar=125
offset=1
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
scalar=125
offset=1
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
scalar=125
offset=1
[channel4]
template=simple
[channel5]
template=expo_dr
[mixer]
src=RUD
dest=Ch5
scalar=-99
offset=1
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
13 Jul 2016 10:38 #51600 by Infamous2117
Replied by Infamous2117 on topic Juncheng 3015-1 / 3015-2
Not sure if anybody has touched on this but the new "Red Board" revision that what was released in the last few weeks is NOT deviation compatible as of yet.
I read it on one of frequent flyers videos and i also cannot bind it to my DEVO 10 (With NRF204L01 Module)
I have tried all format options, no luck.
23 Jan 2018 14:39 #67073 by BAL00
Replied by BAL00 on topic Juncheng 3015-1 / 3015-2
I'm searching for this (or any other good) version for my Juncheng 3015-1 (with green bord). On this dropbox ling not found) :(
24 Jan 2018 02:03 #67097 by C0ckpitvue 777
Try the cx10 blue board board. protocol and scroll sub options.
24 Jan 2018 13:52 #67119 by BAL00
Dear C0ckpitvue 777,
Thank You for your answer. In my version (v5.0.0-f9f36d5) I have only CX10>Blue-A protocoll, without any sub options. :( which version has sub options (under CX10>Blue.....)??
24 Jan 2018 20:34 #67128 by C0ckpitvue 777
v5.0 3c30cbd
24 Jan 2018 20:37 #67129 by C0ckpitvue 777
Did you scroll down in the options page of the cx-10 ini and high light cx10 next to reinit button and press enter?
24 Jan 2018 20:43 #67130 by IKKI
This is my screen
24 Jan 2018 21:42 #67132 by BAL00
Of course I tried it, but not binding with my copter. :(
Time to create page: 0.049 seconds
