WLToys V931 (V977 V2)
26 Nov 2015 06:52 - 10 Jan 2016 23:20 #40398 by Birdman
WLToys V931 (V977 V2) was created by Birdman
Devo8s
Has trims for 6G (when hovering in 6g mode, use trims as normal)
11CH
CH1 = Thr
CH2 = Ail
CH3 = Ele
CH4 = Rud
CH5 = D/R > AIL DR0 = -100 > Low (Normal)
.....................AIL DR1 = 100 > High
CH6 = TH > RUD DR0 = -100 > Off
...................RUD DR1 = 100 > On
CH7 = FM > FMOD0 = -100 > Normal
....................FMOD1 = 100 > 3D (idle up)
CH8 = 6G > GEAR 0 = -100 > On (6 axis)
....................GEAR1 = 100 > Off (3 axis)
CH9 = Pitch Travel Adjust
CH10 = Ail Trim
CH11 = Ele Trim
MIX0 = Rates 60, Expo 50
MIX1 = Rates 80, Expo 25
MIX2 = Rates 100, Expo 0
Default settings (all switches 0)
Flight Mode = Normal
6 Axis = On
Rates = Low (Normal)
Hold = Off
Mix = Rates 60, Expo 50
Subject to change with more flights.
Will add more info if any interest.
Bm
Last edit: 10 Jan 2016 23:20 by Birdman.
26 Nov 2015 08:49 - 26 Nov 2015 08:50 #40399 by Birdman
Replied by Birdman on topic WLToys V931 (V977 V2)
Could someone please confirm if this protocol should be set to 250kbit/s
www.deviationtx.com/forum/protocol-devel...-v977?start=20#22965
cheers
Bm
Last edit: 26 Nov 2015 08:50 by Birdman.
09 Dec 2015 04:54 #40739 by cmpang
Replied by cmpang on topic WLToys V931 (V977 V2)
Birdman wrote: Devo8s
11CH
CH9 = Pitch Trim
CH10 = Ail Trim
CH11 = Ele Trim
Bm
any difference to perform trim on the native devo Tx sticks (CH2-4) rather than using CH9-11 ?
cmPang
09 Dec 2015 10:21 #40745 by Birdman
i asked myself the same question. did some tests and could not at the time tell any difference. may need more testing
I still have both setups in tx
in the end i went with 9,10 and 11 as i figure there may be some reason they dedicated these channels
Bm
09 Dec 2015 11:22 #40747 by cmpang
Birdman wrote: i asked myself the same question. did some tests and could not at the time tell any difference. may need more testing
Bm
My guess (as I haven't update to the latest nightly yet) is:
In 6G mode, should there are offsets in the gyro calibration, you can try to balance them by the usual stick trim for the CURRENT flight only. After the flight ends and you start up another flight after battery replacement, the flight control on board the heli would again thinks the trimmed stick is in fact the new centre and void any trims you have performed in the first flight.
To say it simple, with the stick trim, you have to perform trim on every subsequent flights..
But with CH9-11, I guess it would trim the gyro and so once balanced, it will take effect for many flights to come until the gyros are offset again..
Please see if it makes sense in your next flight...
cmPang
09 Dec 2015 11:49 #40749 by Birdman
i understand
will give it some thought and test
cheers
Bm
09 Dec 2015 13:58 #40752 by cmpang
will my devo7e-v4.0.1-67f35do capable of 11 channels on KN protocol?
10 Dec 2015 01:38 #40767 by denis747
Replied by denis747 on topic WLToys V931 (V977 V2)
The extra channels are used as virtual channels which act as switches for example to switch between dual rates or between 3g/6g mode, I believe.
I have a devo7e.
10 Dec 2015 02:49 #40771 by Birdman
so you are able to select up to 11 channels on kn protocol with 7e?
Bm
10 Dec 2015 03:03 #40772 by cmpang
nop.. only 8
i use my 7e for all my rc planes.
current version is the most stable one up to now and so a bit hesitate to install the nightlies.
cmPang
10 Dec 2015 07:45 - 10 Dec 2015 07:58 #40777 by denis747
Here is mine, I am using the latest nightly. Showing 11 channels on Kn protocol.
Last edit: 10 Dec 2015 07:58 by denis747.
10 Dec 2015 08:05 #40779 by cmpang
i see. thx
10 Dec 2015 08:11 #40780 by denis747
You are welcome. If you install the latest nightly it will have 11 channels.
Time to create page: 0.046 seconds
