- Devo noobie. Have 8s looking for config for 350QX3
- Crossrock
V2 firmware versions won't work on the V3 firmware - the moved RTF from a dedicated channel to a new flight mode value.
- Crossrock
- jesmail
- Crossrock
PS... I will also be setting up a JIYI P2 Pro with the Devo 8s. It wont work properly with my DX6i as u cant use mixes and dx6i doesnt have switch assignment just mixes
- jesmail
Here are some the Gear switch is RTH it will override all other modes
The RUDD D/R will arm and dis-arm the motors.
FMOD is the flight control selection. 0 - smart 1- stab 2- AP mode and if you go to Mix 2 it will go into AERO
You can check the modes out on the ground via the light on the quad.
I wrote this model so if some thing does not look right let me know. I can check/verify when I get back home.
- Crossrock
- jesmail
Been flying mine for some time and can not tell you the last time it was calibrated. It seems to hold great. I assume you have the little popup GPS, if not that can cause issues. Mine started out as the first generation QX and I upgraded it as they came out with the newer versions. Really happy with it now.
On the JIYI did you get the P2 or plain? I bought one of the P2's plan to put it into a quad that has the APM 2.6 in it.
- Crossrock
- jesmail
On the QX3 I never had a fly away. One of the things to watch on all the quads is vibrations. To me that is the biggest cause of fly away's. The vibrations if they get severe enough will swamp out the gyro's and then you are out of control. I have several friends I fly with and every time one of them has the fly away issue, I find it has bad props or other issues that cause a bad vibration and boom there they go. I had one using the APM , I smacked a june bug and chipped the prop, was coming back at max speed and as soon as the vibrations started the quad shot straight up and then back down doing a couple of flips in the process. ( my friends thought I was showing off!!) I was able to change the throttle to get it out of resonance and set her down without a scratch. But was lucky.
So have fun and keep flying!!!
- Crossrock
- Seven5555
- Seven5555
How do I get it to behave like a spectrum's bind button? do i need to install another switch by soldering it to the buttons or throttle trim?
- HeliPriest
thank's
- HeliPriest
What i do is, i power on the Blade and when it goes in bindingmode i power on my Devo8s and i tab in the mainscreen on te Quadcopter picture and than the setupscreen pops up and then i go one screen further and there you see the button connect/binding and tab that....and that's about it!!??
But i don't know what transmitter you use??
sorry if this does not help you..
- Seven5555
I'm also grateful for the guys that make these configurations. I just wish I could get one of them to work.
- Crossrock
- Seven5555
Crossrock wrote: What stick sequence do u use to try and arm the quad?
Both in, both in and down, both in and up, both out, both out and down, both out and up.
I would like it if one of my switches could be used to arm it. Do you know how?
Thank you for your help.
- Crossrock
- Seven5555
Model Configs
