Trims and Sub Trims
- Morlacus
- Topic Author
21 Apr 2018 06:38 #68779
by Morlacus
Trims and Sub Trims was created by Morlacus
I want to transfer the value of a trim to a sub- trim.
My trim (on elevon) makes the neutral position to be -6%
Is there a way to calculate the value to add to my Subtrim which is -18.3
In the ini file The trim is -66,0,0 (why 3 figures) and the subtrim -183
Should I add -66 to -183 to transfer my trim to my subtrim ?
Is there a way to see the value of the trim (-66 here) except looking into the ini file ?
Sorry if this question has already been treated but I have not found in the forum.
Morlacus
Morlacus
- Fernandez
21 Apr 2018 13:29 #68781
by Fernandez
Replied by Fernandez on topic Trims and Sub Trims
that is a good question, btw it would be an excellent feature, some function in the Tx model menu transfer trim to Subtrim, in order to set all trims to middle position, when the model has got it's maiden.
- Morlacus
- Topic Author
22 Apr 2018 17:34 #68795
by Morlacus
Replied by Morlacus on topic Trims and Sub Trims
Agreed, but I am not so demanding...
I would be pleased if I was assured that my assumption that adding the trim and sub trim values of the ini files and putting the result in the subtrim value and zeroing the trim value would correctly transfer the trim value to the sub trim.
Time to create page: 0.025 seconds
- Home
- Trims and Sub Trims
