Devo 7E - Assign a key to 7th channel
- doug01n
- Topic Author
22 Feb 2021 18:01 #77270
by doug01n
Devo 7E - Assign a key to 7th channel was created by doug01n
Hi!
Now I have a Devo 7E and using it with my Mobula 6 quad.
My question: Devo 7E is a 7 channel radio, right? It has only 2 switches (Hold and Fmode). I'm using Hold to arm the quad, and the Fmode to switch between Level mode and Acro mode.
Is there a way to use the 7th channel assigning it to another key, or do I have to do the "add switch" mod in my Devo7?
I would like to assign the "Horizon" mode to the 7th channel, or even the "turtle mode".
Thanks, guys!
Thanks, guys!
- yets
24 Feb 2021 20:05 #77273
by yets
Replied by yets on topic Devo 7E - Assign a key to 7th channel
Have a look into virtual channels. You can turn the trims as a switch to turn channels on and off.
Edit the trims under the menu heading and then assign the trim to a channel switch
- -=Hubi-Dirk=-
27 Feb 2021 19:15 #77279
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo 7E - Assign a key to 7th channel
For the Future you can also add very easy two more switches to your Devo 7e.
Have a look here: deviationtx.com/forum/how-to/1436-add-tw...-to-the-devo-7e#6379
- Home
- Devo 7E - Assign a key to 7th channel
