Genius WK2801Pro mode
24 Oct 2012 20:52 #2404 by NewJocker
Genius WK2801Pro mode was created by NewJocker
Here it is WK Genius
07 Feb 2013 08:48 #6116 by Parees
Replied by Parees on topic Genius WK2801Pro mode
Heads up for any one using this config. Channel 7 (which is gyro) is not setup correctly. It needs to be a flat value (I use 78%).
I spent two days trying to figure out why my genius cp was spinning ccw on applying any amount of throttle.
I'll upload the corrected config file later when I get to my computer.
09 Feb 2013 18:02 #6176 by Parees
Here's the updated model cfg with channel 7 correctly set to enable to gyro. I've also added a mix to the rudder such that as throttle increases, the rudder also adds more right (nose right) to compensate for a slow CCW yaw that my genius cp has while hovering. The mix is enabled with the MIX1 switch.
Time to create page: 0.021 seconds
