EFLITE MSR ICON DEVO7E, HELP RGB565
23 Jan 2013 20:23 - 25 Jan 2013 20:08 #5437 by Lyndros
EFLITE MSR ICON DEVO7E, HELP RGB565 was created by Lyndros
Hi all,
I have done a .bmp for DEVO7E in BMP. Gimp for windows does not include the option to export it to RGB565 and I can not find a decent converter.
Can anyone convert the file or can tell me an easy program to perform this conversion ?
Cheers,
Lyndros
Last edit: 25 Jan 2013 20:08 by Lyndros. Reason: Add good export
23 Jan 2013 20:27 #5438 by FDR
23 Jan 2013 21:39 #5439 by Lyndros
Replied by Lyndros on topic EFLITE MSR ICON DEVO7E, HELP RGB565
Yes I have tried but this advanced option is not available in GIMP 2.8 for Windows. :-(
Any other idea?
  • rbe2012
  • rbe2012's Avatar
24 Jan 2013 06:17 #5449 by rbe2012
Replied by rbe2012 on topic EFLITE MSR ICON DEVO7E, HELP RGB565
It is. You have to export the picture as Windows BMP and when you click on "save" (sorry, have no english version, but the button should be named alike). A little dialog appears with a radio button and two "+"-signs. By clicking on the lower there appear a few options - one of them is "R5 G6 B5", another is A1 R5 G5 B5" - the second for images with transparency.
24 Jan 2013 08:56 - 24 Jan 2013 08:58 #5453 by dc59
Replied by dc59 on topic EFLITE MSR ICON DEVO7E, HELP RGB565
Lyndros wrote: Yes I have tried but this advanced option is not available in GIMP 2.8 for Windows. :-(
Any other idea?
This is what I done.
1. open your file by Windows 7 Paint
2. "Save as" -> BMP 24bit format
3. Open it with GIMP 2.8
4. Export -> Windows BMP format
now you can use advanced option .....
done
Last edit: 24 Jan 2013 08:58 by dc59.
24 Jan 2013 08:59 - 24 Jan 2013 09:03 #5454 by dc59
I can't upload modified file................
I don't know why ??????
Last edit: 24 Jan 2013 09:03 by dc59.
24 Jan 2013 22:48 #5483 by Lyndros
Hi dc59,
Thanks for your tip after exporting to 24 BIT Bmp, the advanced options appeared and I could export to RGB565.
I loaded in my transmitter and works like a charm.
Here you have the new working image already exported.
Btw,
What is this softare that you are using to edit the models ?
I have just started with the deviation firmware :-)
25 Jan 2013 00:47 #5486 by dc59
Lyndros wrote: Hi dc59,
Btw,
Edit models? you mean model icon or config?
I use GIMP to edit model icon(I am really not good at this! :S )
About model config,I just use TX to edit all parameter.
25 Jan 2013 05:24 #5496 by FDR
Replied by FDR on topic EFLITE MSR ICON DEVO7E, HELP RGB565
That is the emulator on the picture...
25 Jan 2013 18:53 #5515 by Scream
Replied by Scream on topic EFLITE MSR ICON DEVO7E, HELP RGB565
SWEET!!
Thanks so much guys!
I don't know why, but I was not having any luck with icons even following the steps until this thread.
Now I "finally" have a MSR icon!
Cheers!!
-=S=-
Cheers!
-=S=-
25 Jan 2013 20:09 #5517 by Lyndros
No problem dude,
Hope you like it :-)
PS: I will install the emulator to check
Time to create page: 0.055 seconds
