- Model Requests
- FPV Raccer simulator, please Help !!!
- justyn07
- mario123
Only when calibrating with windows the digrams show crap, but if you enable Raw Data, you can see it's working properly.
Mario
- HaCo
- mario123
![:) :)](/media/kunena/emoticons/smile.png)
Has anyone of you got this to work with the android version. My mobile sees the devo but the app can't see any inputs from it. I think it's missing permissions but I don't have a clue how to fix this. Anyone have an idea what i could try?
- grouver
mario123 wrote: This is mine if still needed. It's working with FPV Freerider and RCDeskPilots.
Mario
Thanks for the ini, everything works now
- kchupe
- mario123
With protocol USB HID
- AeroRoo
Arakon wrote: Setting an expo curve with 3 points at 0, 50 and 100 for all channels works fine.
Hello Arakon, I hope you see this after such a long time since you posted!
It seems this is the fix, but I'm failing to find how to set this Expo Curve in my Devo-10 with Deviation 4.0.1 firmware. Are there any guides on how to set this Expo Curve for all channels? A few posters in this thread have said it worked for them, so hopefully one of them sees this
If anyone knows how to set up this Expo Curve on a Devo-10 running Deviation 4.0.1 - please let me know!
![:woohoo: :woohoo:](/media/kunena/emoticons/w00t.png)
- AeroRoo
1. I downloaded the Devo model file from here: drive.google.com/file/d/0BwSDHIR7yDwSM0Z...ZXc/view?usp=sharing
2. I connected my Devo-10 to my computer in USB mode and dragged the above Devo Model file into the 'models' folder of the Devo-10 USB device.
3. Important! If you try and look for the above Devo model file in your transmitter, it won't see it. The Devo-10 only recognises model files that are called model1.ini, model2.ini etc. I suggest replacing your model1.ini file with the above Devo model file and renaming it to model1.ini
4. Turn off the USB mode and press ENT on the main screen. Go to 'Model Menu' and then 'Model Setup'. Select 'Load' in the 'File' option and you'll see a FPV Freerider model in there
5. Select this model, load up FPV Freerider on the PC and calibrate the controller. I'm now flying and crashing successfully!
If you're still having trouble, here is a good guide:
itch.io/t/19817/getting-your-controller-connected
- doc99337
I am having trouble in configuring the RUD. Seems not working properly.
Is it really required to be in model1?
- Koekebeest
Please help. I so much want to learn acro
![:( :(](/media/kunena/emoticons/sad.png)
- Koekebeest
- MadMenace303
doc99337 wrote: Hi,
I am just going to throw this out there for anyone else with this issue. I too had this issue, on both computers, and almost went bald trying to configure this thing for several weekends Recently I found that if you also have Smartpropo plus and or vJoy installed that it somehow conflicts with the devo7e USBhid and stops the sim from seeing the rudder commands even tho the channel monitor shows them operating perfectly, Simply UNinstalling vJoy solved all my issues on both computers.
so if you have no rudder and you've previously installed vJoy and smartpropo plus, uninstall them
- Dwayne1
I have completed the following steps:
Downloaded model.ini file and loaded onto my Devo 10
Renamed the .ini file
In setting up a new model, I am having trouble getting my tx to bind using the usbhid protocol.
I'm new at this, so am probably overlooking something really simple.
Almost forgot to mention I am trying to set this up for FPV Freerider, and have followed all the instructions for setup.
Thanks in advance for any help.
- Old_Okie
Hope this helps lots of people.
John
- Kv
- Model Requests
Model Configs
Model Requests
