Eachine E58,
- Burntstanding
- snod33
All the Best Ian
- ndwest
- snod33
Ian
- Sparkey35
- Burntstanding
Was also considering either looking at dumping and reflashing the ESP chip that is attached to the camera module that lines in from the Wifi Control app as I've captured the packets sent from the wifi module to the flight controller and they are single line serial that mirror the structure of the UDP broadcast packets. It would be possible to put a Frsky RX or similar with a small micro controller maybe an ATiny to translate the PPM from the RX into the commands that the Wifi module bumps down the the PAN159CY Flight controller.
- flaming_goat
- amid
Congratulations guys, very good work. I want to continue investigating just for fun.
Someone could record the video streaming through a PC, with FFMPEG or something similar?
Tried sending commands with netcat or similar?
- sylvaiw
I would like to bind E58 and Taranis X9 lite...
Did some-one finally find which protocol to use ?
Thanks.
- MAYANK kumar singh
Actually I also have eachine e58 , but one day I opened it and for just testing I inserted the battery in reverse direction and suddenly one of the regulator chip FUSED.
so I just wanted that.......sir that.......can you just snap a clear picture of your drone's reciever so that I can just get a glimpse or the name of the part fused ,so that I can replace it. Please it's a request I would be so delighted if you help me sir
Please please please please please please please please please please please please please please please please please please please
Sir please
- Sparkey35
God bless you pal
- om-drones
- Telpenar
- Home
- Model Requests
- Eachine E58,
