- Model Requests
- Jumper T8SG V2 PLUS cant calibrate on FPVFreerider
- Iken82
- Topic Author
16 Apr 2019 03:40 #73914
by Iken82
Jumper T8SG V2 PLUS cant calibrate on FPVFreerider was created by Iken82
Has anyone encountered this? What's the fix? I'm using Windows 7 and already tried messing around with the mixer but still no luck. Any help would be much appreciated. Thanks.
16 Apr 2019 03:51 #73915
Replied by vlad_vy on topic Jumper T8SG V2 PLUS cant calibrate on FPVFreerider
On Windows, you need to setup so that the joystick channels go from 0 at minimum to 100 at maximum (instead of -100 to +100).
Try to use complex mixer and set for channels: scale = 50, offset = 50.
- Iken82
- Topic Author
16 Apr 2019 04:06 #73916
by Iken82
Replied by Iken82 on topic Jumper T8SG V2 PLUS cant calibrate on FPVFreerider
Thanks for the reply! But in the mixer, for each channel, i cant find the offset option. Just how do i go about in changing the settings? I cant find any video of it anywhere.
16 Apr 2019 06:19 - 16 Apr 2019 06:22 #73917
Scroll mixer page down. Even simple mixer has scale and offset options. Press on "Simple" (Expo&DR or Complex) button, not channel number.
Last edit: 16 Apr 2019 06:22 by vlad_vy.
- Model Requests
Time to create page: 0.033 seconds
- Home
- Model Requests
