Blade Nano S2
- jerrysimon
- Topic Author
24 Aug 2019 08:49 #74978
by jerrysimon
Blade Nano S2 was created by jerrysimon
Does anyone have a T8SG Plus ini file for this ?
Jerry
Jerry
- enzo
30 Aug 2019 21:41 #75059
by enzo
Replied by enzo on topic Blade Nano S2
Blade Nano S2 INI file for T8SG Plus
I found this great Japenese YouTube video that has T8SG settings for the Blade Nano S2 but the .ini file they provided was a bit broke since the collective did not work in 3d mode, anyways i fixed it so this .ini file uploaded here should work for you!
Switch conditions:
A0 = SAFE + LowRate (90%)
A1 = SAFE + HighRate (100%)
A2 = 3D + IDL_up (NOTE!!! after watching the video they did somthing realy cool, if you fuck up in 3d mode just flick the button into A0 or 1, this causes the helo to flip upright and stabilize, it is like a better verison of using panic mode except you still have control)
D 0 = N / A
D1 = Thr-CUT
D2 = Thr-CUT
G 0 = N / A
G1 = Thr-CUT
H 0 = N / A
H1 = Thr - CUT
More helpful videos from these guys:
[TIPS] How to register the downloaded DeviationTx model INI file (T8SG V2 Plus)
Please like their chanel, figuring this tramitter out is still confusing to me but after getting their ini file and fixing it, I was able to get the heli flying the way I wanted.
Switch conditions:
D 0 = N / A
D1 = Thr-CUT
D2 = Thr-CUT
G 0 = N / A
G1 = Thr-CUT
H 0 = N / A
H1 = Thr - CUT
- jerrysimon
- Topic Author
31 Aug 2019 07:26 #75063
by jerrysimon
Replied by jerrysimon on topic Blade Nano S2
Yes thanks for that. I found that a while ago and have been using it successfully with my new S2
- enzo
08 Sep 2019 15:00 #75087
by enzo
the ini. is at the bottom of my main post, click the little atachment file button.
- jerrysimon
- Topic Author
08 Sep 2019 15:08 #75088
by jerrysimon
Their ini file does work but you have to hold the stick left as if you are setting it up for a non computer radio. They have done some clever programming to achieve this mimicking the stock non computer radio usually supplied with the RTF version
I did not see yours but will take a look at it as well. Thanks
- txinsuranceguy
12 Jan 2020 05:49 #75691
by txinsuranceguy
Replied by txinsuranceguy on topic Blade Nano S2
Hiya... so when binding t8sg I hold rudder left?
I held it right per the manual. Using the YouTube ini the voices worked.
Using the one you posted no voices...I can add them later.
Also when calibrating the heli I can get into the calibration but since no panic button how would I do it?
- rcscale101
15 Jun 2020 15:11 #76471
by rcscale101
Replied by rcscale101 on topic Blade Nano S2
Newbie here, don't hit! How can I make it work on a Devo 7e (firmware 5)? Is it even possible? Will I be able to switch between 4D and 6D?
Thanks for your light!
Time to create page: 0.033 seconds
- Home
- Model Requests
- Blade Nano S2
