6Ch Plane predefined mixer template
- kreidler
02 Jan 2014 21:50 #17778
by kreidler
6Ch Plane predefined mixer template was created by kreidler
The mixer system of Deviation has enormous capabilites. Unfortunately every model has to be done from scratch or by editing the model.inis.
My aim is to have a template for planes where any of the most needed mixers are already available and which could be included later on into a release. I just want to collect some additional input from all users around here if something else might be more important to implement. Afterwards I will do a small PDF guide how to use the mixers. I did partly some useful presets already.
Included are
Any of these virtual mixers except for the Differentials can be applied with mux-type 'add' on a complex template. Differentials must use 'replace', if needed. Expo or DR can be applied direct on the channel without having the mixing in the template. The mixing has to be adjusted in the virtual channel setup.
Please bear in mind that this template is for an acro model or a (electric) sailplane with two ailerons only.
Any suggestions what to improve?
Included are
- Virt1 (still available)
- Differential Left Aileron
- Differential Right Aileron
- Combi-Switch
- Spoileron
- Flaperon
- THR-Compensation
- Spoileron-Flaperon-Compensation
- V-Tail Left servo
- V-Tail Right servo
- kreidler
05 Jan 2014 17:55 #18003
by kreidler
Replied by kreidler on topic 6Ch Plane predefined mixer template
Please note that flaperon and spoileron will work for Devo10 and Devo12. All others not having pots for AUX4 And AUX5 have to be redefined to a switch or trim.
- pietekepuntnl
12 Jan 2014 14:20 #18411
by pietekepuntnl
Replied by pietekepuntnl on topic 6Ch Plane predefined mixer template
thank you so much. i'm gonna look at it and try to understand how everything works. i find it hard to learn but it's a challenge and challenges are to be taken. i've got a sailplane with additional ailerons so i'm happy with your work !!thanks again
- unclecrash
08 Jul 2014 04:54 #24465
by unclecrash
Replied by unclecrash on topic 6Ch Plane predefined mixer template
Wondering if you are still going to make a pdf on how to use the mixer,I could sure use it. Davekreidler wrote: The mixer system of Deviation has enormous capabilites. Unfortunately every model has to be done from scratch or by editing the model.inis.
Included are
- Combi-Switch
- Spoileron
- Flaperon
- THR-Compensation
- V-Tail Left servo
- dat
08 Aug 2014 01:22 #25089
by dat
Replied by dat on topic 6Ch Plane predefined mixer template
thanks a lot, very very usefful template.
i use it on my 12S to fly my fomosa thunder , everything is ok ,
but i don't know how to setup flapron , i do my best to try whichever measures
and never success.
here is my model.in that i used. any advise to me? thanks again.
and never success.
- kreidler
08 Aug 2014 14:32 #25095
by kreidler
@unclecrash: Yeah I am still alive. atm is outdoor season and may other projects are waiting for some progress. Manual might be in northern hemisphere winter time.
@dat: In general no virtual input is saved with your ini. E.g.:You have to add the virtual channel 'Flaperon' to your channel definition.
Afterwards you could adjust the servo movement by using AUX5 trim.
But you know what flaperon stands for? Flaps AND aileron. So, as far as Google told me Formosa is a small park flyer with ailerons only. In this case You will be able to shift the center of the ailerons only. Making the ailerons working as flaps. I am wondering if this makes sense to your model?
[virtchan6]
name=Flaperon
template=simple
[mixer]
src=AUX5
dest=Virt6
scalar=-50
offset=50Afterwards you could adjust the servo movement by using AUX5 trim.
- StocKi
27 Mar 2015 09:36 #30323
by StocKi
Replied by StocKi on topic 6Ch Plane predefined mixer template
Hello
could anyone tell me if this would be a suitable template to use on a Parkzone iX? the plane has no flaps but will have retracts and I would like to set up a dual rate setup.
Help would be appreciated
28 Mar 2015 11:12 #30357
Well, I'm not kriedler, but I wrote a tutorial on how to create a model config , which is mostly about the mixer. It might help.
Replied by mwm on topic 6Ch Plane predefined mixer template
unclecrash wrote: Wondering if you are still going to make a pdf on how to use the mixer,I could sure use it. Dave
- dat
22 May 2015 00:37 - 22 May 2015 01:08 #32850
by dat
hi kreidler , sorry for so long and just reply
yes , formosa is a 450 motor class little plane
here is the pic !
i am already done this , and install a ZYX-s gyro on this little guy now ,
it flight great , lots fun to fly do some f3a and 3d act !
here is the pic !
Last edit: 22 May 2015 01:08 by dat.
Time to create page: 0.879 seconds
Model Templates
- 6Ch Plane predefined mixer template
