Voice Template for T8SG V2 Plus - EN & FR Package
04 Dec 2020 10:20 #77087 by Tinee
as you know, for T8SG you can add voice for alert, event or command.
To activate the Voice, you can refer on the wiki page here
Voice alerts packages are available in zip file from Test Builds/[Moeder]voice_packs or in the voice packs created by Deviation Voicepacker.
I downloaded the package in French & English, as on different place I would prefer a specific language. However, some missmatch were existing between FR and EN Code (as you can do your own voice) and on the FR package, you had duplicate codes with different meaning. So, it was not possible to switch easyly between the 2 language. For this reason I did 2 packages for this 2 languages with missing voice added (or new I needed) with a corrected numbering.
You will be able to find the release note, and xls which contain formula to write your ini file if you want to do yours, and the removed voice from French package which were in conflict with another voice with the same numbering. Hope it will be fine for you.
Tinee (Hawk)
Time to create page: 0.023 seconds
