V202 protocol
- cyberbillp
burburx wrote: I dont actually know how protocols work but I made some experiences. First with DEVO 7e modified with nrf24l01 it drops all the time. With new transmitter is do not drops till the thirh or second cell.I looked and see that receiver card heated. Meybe card heat end stops sending power. I thought if we bybass supply of voltage to receiver we can maybe find solution by the way
The nrf24l01 certainly seems to have some kind of power problem. I have one with the PNA but its range is pitiful. Something bad is going on with it.
- phantom8
The range for my nrf24l01 is pretty good. I can fly my quads till I can no longer visualise its orientation, probably over 100m. However, I do encounter a bug which sometimes corrupt the Devo screen. I thought that had been reported long time ago and was fixed.
- hanryz
- cyberbillp
My v202 and v252 both drop mere feet away, same distance for massiveoverkill as well with his quads.
- SeByDocKy
- warewolf75
im looking for model config for my v212, or maybe somebody can help me understand the hole complex adjustement so i can do it my self, i would like my quad to be able to have nice smooth flight on fmod switch 0 and a full agility mode on fmod 1 or something like that so i can do flip and even loop if possible, i already had my devo 7e with deviation and took the original remote nrf module, binding is ok, but have to re do it everytime, i had a few flight but no info on how to create my own config, can anybody help me out ??
- victzh
- warewolf75
- warewolf75
do you think the 180qx board wuold be more effective for fine tuning ?
i would like it to be as agile as the traxxas alias, is it possible ?
- jesmail
I am using 4.0.1 on a Devo 8S with nRF24L01 module and external antenna.
On mine I have to rebind every time.
Thanks.
Anybody else using this protocol?? Do you have to rebind every time you start up the Heli?
If so it would be nice if we could put the rebind on a switch so that we would not have to go into the menu to start a rebind.
- jesmail
- victzh
- jesmail
I do not have to rebind each time with the original controller.
So if it is possible to add the option to start that would really be nice. I am using the latest nightly build.
Thanks again
- victzh
- jesmail
I use Devo with Walkera's
I use DSMX with Blades.
Do you need a copy of my V222 Model.
- victzh
What I can do is to replicate this behavior, just without throttle movement.
- jesmail
PS I know how to replicate the stick movement, but since it does not bind it on the 8S, I don't see how that will help.
- victzh
- jesmail
- victzh
- V202 protocol
