New Hubsan Upgraded Version on the way
27 Dec 2013 23:56 #17217 by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
Xermalk wrote: Daryon, try rebinding and se if its always 5815.
And holy crap dfuse 2.0 sucks, 4 minutes just to get past the erase phase ? *shudders* i need to locate a download for 1.5.
I normally have a full firmware flash done in under a minute in my vm machine. but i don't have access to it right now.
Lol, I use a windows XP vm too for that, I could never have dfuse to work on my win7/x64 rig.
27 Dec 2013 23:57 #17218 by Daryoon
Replied by Daryoon on topic New Hubsan Upgraded Version on the way
When I used my previous firmware, I believe I recall the frequency being random each time.
Looking at the picture again. I think it's actually 5805 or 5810 that's the best expose picture. 5815 seems over exposed and occasionally has a band that appears across the image.
27 Dec 2013 23:58 #17219 by Daryoon
I am using dfuse on Win7/x64. Works fine and flashes fast.
27 Dec 2013 23:59 - 28 Dec 2013 00:00 #17220 by Xermalk
Replied by Xermalk on topic New Hubsan Upgraded Version on the way
Iv never got any dfuse verson to run on my w7 / x64 machine.
Or more specifically, its never detected my devo controllers.
63% done on the download phase, total time so far 10 min 43 sec. :dry: i hope its not destroying my tx right now.
Last edit: 28 Dec 2013 00:00 by Xermalk.
28 Dec 2013 00:01 #17221 by Daryoon
That's interesting. I simply followed the Deviation manual and it was never a problem. Wierd huh?
28 Dec 2013 00:03 - 28 Dec 2013 00:04 #17222 by Xermalk
Lovley lovley windows :) theres just so much black magic going on under the hood that the results are never the same, even on very similar pcs.
exactly 15 minutes to flash the firmware, but atleast the tx seems to be working.
Last edit: 28 Dec 2013 00:04 by Xermalk.
28 Dec 2013 00:06 #17223 by goebish
Ok, my code works but I made an error, it's late (1:00 am)... I'll build a last version for tonight, this one should be 5945... thanks for your patience, really :)
28 Dec 2013 00:10 #17225 by Xermalk
Bad news, when using the devo 10 version, i got a frequency of close to 5895. but its not 5895 as the picture it near garbage.
28 Dec 2013 00:11 #17226 by goebish
Devo 10:
speedy.sh/Pe7Hv/devo10.dfu
Devo 7e (module only ;)):
speedy.sh/H3bXK/hubsan4.mod
This one should be 5945.
Good night all, see you tomorrow for a proper patch if this works...
Next the telemetry (that will be harder).
28 Dec 2013 00:12 #17227 by Daryoon
1AM. That magic hour for coding. ;)
Thanks to you. Really.
28 Dec 2013 00:17 #17228 by Xermalk
OMG WTF BBQ time. It works brilliantly, its now stuck on 5945 :)
To bad i cant fly or there will be hell to pay this late :P
28 Dec 2013 00:18 - 28 Dec 2013 00:19 #17229 by goebish
Good, I can have a good night now :)
Thanks for reporting.
Last edit: 28 Dec 2013 00:19 by goebish.
28 Dec 2013 00:23 #17230 by Daryoon
I'll let Xermalk chime in.
I flashed my old firmware and old hubsan4.mod protocol file.
I still see the video on 5810Mhz.
I just flashed your firmware and copied over your new hubsan4.mod protocol file. And I expect the video to be on 5945Mhz.
However, I still see the video on 5810Mhz. This is with the Hubsan TX power cycled and everything.
Now, if I bind to the Hubsan TX and VTX. Not using Devo at all. Video seems to default to 5725Mhz. I can change the frequency. And the picture will flash and switch to that new frequency on the fly.
So I decided to select 5945MHz. Video is showing just fine.
I remove the lipo from the X4. Turn on my Devo. Insert lipo to X4. It powers up and bind to my Devo.
But still not video on the Hubsan TX @5945Mhz. I must manually switch it to 5810MHz to see the video feed.
28 Dec 2013 00:24 - 28 Dec 2013 00:24 #17231 by Daryoon
Xermalk wrote: OMG WTF BBQ time. It works brilliantly, its now stuck on 5945 :)
Perhaps I need a new firmware dfu file too?
Last edit: 28 Dec 2013 00:24 by Daryoon.
28 Dec 2013 00:25 #17232 by goebish
I'll try to rebuild, but the .dfu has not changed, only the .mod, weird.
28 Dec 2013 00:26 #17233 by Daryoon
Well, the Devo 10 seem to work.
So we can hack on the Devo7e tomorrow and see why that is. Seems like mine is permanently stuck at 5810MHz now. LOL I swore it was changing on the fly earlier.
Anyways, thanks and good night.
28 Dec 2013 00:28 - 28 Dec 2013 00:28 #17234 by goebish
speedy.sh/UDGFV/7e.zip (rebuilt .dfu + .mod)
Last edit: 28 Dec 2013 00:28 by goebish.
28 Dec 2013 00:32 #17236 by Daryoon
Be right back.
Takes 1min.
28 Dec 2013 00:35 - 28 Dec 2013 00:35 #17237 by Daryoon
Damn. Full firmware flash. Then copied over the new .mod
But still on 5810MHz
Call it a night. We'll hack on it tomorrow when you are fresh.
Last edit: 28 Dec 2013 00:35 by Daryoon.
28 Dec 2013 00:36 #17238 by goebish
That's a mystery, I don't understand why it would work with a Devo 10 but not a 7e (but still use another freq than the default one).
Time to create page: 0.086 seconds
