WLToys V912/V915/? protocols
- goebish
- I Void Warranties
www.dropbox.com/s/m1u5xtzvqm4n8lt/deviat...0.1-d5e268a.zip?dl=0
( gist.github.com/goebish/fd6212b6e99360c9bc63 )
- Deal57
The firmware from post #30013 worked fine with no FixedID. I walked around the house and didn't see any dropouts, all tested at 30mw setting.
This latest firmware from post #30046 works great without a fixed ID. All collective movements are perfect and function buttons work exactly as expected. I took a basic walkaround with no dropouts noticed.
I think I have a lead on what is happening with the fixed ID. I have been using Model 10, so I used "1010" as the fixed ID. If I use that fixed ID with this version, the V912 has the stutters and hesitations. If I use other fixed IDs, like "10101", "1111", any of the 256-271, and the blank fixed ID, there are NO stutters. I captured both streams from the RX. In "V912 RX 1010 fast elevator" I have stutters, but in "V912 RX 10101 fast elevator" the collective is smooth, no stutters. I scaled the capture so it shows about 2 seconds on my screen, and on the "1010" there seems to be breaks in the data (beginning at about the 6 second mark), but in "10101" there aren't any visible at that scale.
dl.dropboxusercontent.com/u/31578062/V91...20elevator.logicdata
I guess "1010" isn't good to use as a fixed ID.
- goebish
- I Void Warranties
So, I was right, it works with some IDs, but not other... will have to stare at the tables again
We're making some progress ...
- goebish
- I Void Warranties
8E, 3E, 7A, 2A, 84, 34, 66, 16, 5C, 0C, 98, 48, 52, 02, 70, 20 (row5, offset -8 )
while with this ID we transmit on:
8F, 3F, 7B, 2B, 85, 35, 67, 17, 5D, 0D, 99, 49, 53, 03, 71, 21 (row5, offset -7)
(eg good row, but bad chanoffset by 1)
So I think the RX receives the data because the channel is close enough, but we don't emit on the right one.
the 1010 data is using row 2 with an offset of 9, but the computed offset should be 15. this is why it isn't working.
I vaguely remember some discussion over at rcgroups about my algorithm being wrong for some txids, but I don't think nayone ever told me what was wrong. I'll go search and see if I can find the discussion.
- goebish
- I Void Warranties
That's why I love this community, I learn tons of things each time I come here
some users are seeing a maximum offset of 9
Deal57,
can you capture with the following txids?
272
288
304
320
336
352
368
384
400
416
432
448
464
480
496
- Deal57
- Deal57
I think you're on to something!
dl.dropboxusercontent.com/u/31578062/V912%20RX%20272.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20288.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20304.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20320.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20336.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20352.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20368.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20384.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20400.logicdata
dl.dropboxusercontent.com/u/31578062/V91...0No%20Bind.logicdata
dl.dropboxusercontent.com/u/31578062/V91...20Stutters.logicdata
I think the best thing to do is to truncate the offset at 10 for all models. I don't know if any support values > 10, but all will work between 0 and 9.
There are 2 options:
1) just use: 'if offset > 9 {offset = 9}
2) use something like id = (Model.txid & 0xff00) | (Model.txid % 160) which would never get an offset > 9. I wouldn't actually use modulo, since it requires needless division
Either way it is backwards incompatible, but I am ok with that. There is no reason to have an option to enable this configuration. I'll let goebish decide what he wants to do and have you test it.
- goebish
- I Void Warranties
If we use 1), there's a risk a Rx can allow offset >9 and doesn't work ?
www.dropbox.com/s/3rph570j3kou8xn/deviat...8a_txidhack.zip?dl=0
( gist.github.com/goebish/f1879228b8cf93333009 )
- goebish
- I Void Warranties
PhracturedBlue wrote: 1) just use: 'if offset > 9 {offset = 9}
or maybe you mean only modify high nibble from id low byte if it's >9 ... I didn't understand at first, I thought you wanted me to change chanoffset without modifying txid.
- Deal57
Nice work! What next?
- goebish
- I Void Warranties
- goebish
- I Void Warranties
The only problem I see with the latest patch is as you said it is backwards incompatible, so certain FlySky Rx may need rebind.
- Deal57
I tried this new firmware with my V911 and it flies great as long as WLToys ext. is Off. I DID have to rebind the first time I used it. When I tried to use the (current) V91x option, the heli spins. I set channels to 4 and 8 and it just spins. So we wouldn't want someone selecting this for the V911. We also need to test it on a V913 and V915 but I don't expect a problem there.
On the other hand, the V912 flies nicely. And the camera functions worked!
- goebish
- I Void Warranties
Other than the code, it would be cool if someone with a better English than me updates the manual regarding new WLToys options & channels features for v6x6 and now v912.
(I can update the French manual if it exists)
For the 912, I'll use channels 5 & 6 to simulate top and bottom buttons, 6 & 7 were a mistake.
- goebish
- I Void Warranties
Deal57 wrote: On the other hand, the V912 flies nicely. And the camera functions worked!
How do accessories work ? Are they controlled only with top and bottom buttons ? What if you've more than 1 accessory on the copter ?
- WLToys V912/V915/? protocols
