EAchine / Gin H7
  • goebish
  • goebish's Avatar Topic Author
  • NRF Weirdo
28 Jun 2015 19:15 - 03 Jul 2015 11:22 #34804 by goebish
EAchine / Gin H7 was created by goebish
Hey,
I just implemented the EAchine / Gin H7 protocol (requires nrf24l01), here are test builds:
Devo 7e: www.dropbox.com/s/xe5mdprhqru1niu/deviat...e-H7%20test.zip?dl=0
Devo 10: www.dropbox.com/s/fry4c2g480pq7cq/deviat...0-H7%20test.zip?dl=0
Channel 5: rate
Channel 6: flip
Channel 7: elevator trim ( see this post )
Channel 8: aileron trim ( see this post )
Source code:
bitbucket.org/goebish/deviationtx/branch/EAchine_H7
Last edit: 03 Jul 2015 11:22 by goebish.
  • goebish
  • NRF Weirdo
28 Jun 2015 19:23 #34805 by goebish
Replied by goebish on topic EAchine / Gin H7
If you're looking for a nano quad I really recommend this one, it's a tad bigger than cx10 but flies way better !
28 Jun 2015 19:58 #34806 by SeByDocKy
Replied by SeByDocKy on topic EAchine / Gin H7
It's binding and I can fly after inverting AIL & ELE in mixer. Drifting/sliding to the left
  • goebish
  • NRF Weirdo
28 Jun 2015 20:36 #34807 by goebish
Thanks, this should be fixed now, guess I've bad template files in my TX with swapped aileron & elevator channels :p
Use channel 8 to fix the aileron drift, or channel 7 for elevator drift.
  • goebish
  • NRF Weirdo
28 Jun 2015 20:48 - 30 Jun 2015 14:06 #34808 by goebish
Speaking of protocol trims, I'm a bit ashamed to ask, but how do I assign trim switches to a channel ? eg 1 click on left aileron trim switch = -5% on channel 8 (+ stop this trim button from acting on aileron channel).
edit: that's as simple as that:
www.deviationtx.com/forum/protocol-devel...eachine-gin-h7#34882
Last edit: 30 Jun 2015 14:06 by goebish.
29 Jun 2015 09:49 #34824 by dc59
Replied by dc59 on topic EAchine / Gin H7
Hi Goebish,
Is this build support Eachine H8 Mini quad.?
  • goebish
  • NRF Weirdo
29 Jun 2015 10:23 #34825 by goebish
No idea, just try :)
30 Jun 2015 02:54 #34872 by dc59
I tried, but ...........didn't work ...............
Anyway Thanks ~~
30 Jun 2015 05:43 #34875 by SeByDocKy
For the H7, by default the quad is shifting forward ....I don't know if for your also ?
  • goebish
  • NRF Weirdo
30 Jun 2015 10:48 - 30 Jun 2015 10:48 #34881 by goebish
It is because you've to set protocol trims ....
(I think they set accelerometer offset)
Last edit: 30 Jun 2015 10:48 by goebish.
  • goebish
  • NRF Weirdo
30 Jun 2015 11:42 - 30 Jun 2015 14:21 #34882 by goebish
SeByDocKy, here's how to assign trim switches to protocol trims:
Go to Model menu -> Trims
Then configure like that (mode 2):
(why 3.3 step ? because the stock tx has 31 trim steps on each side, 100/31 = 3.22)
Then the trim switches will set the protocol trims :)
I found that H trim direction is inverted, I'll fix it in code later, but first check that it works for you please.
Last edit: 30 Jun 2015 14:21 by goebish.
  • goebish
  • NRF Weirdo
30 Jun 2015 14:32 #34892 by goebish
Uploaded new version with fixed H trim direction.
30 Jun 2015 14:40 #34894 by ThomasDB
Replied by ThomasDB on topic EAchine / Gin H7
I have tested with the H8 Mini, it does not bind.
  • goebish
  • NRF Weirdo
30 Jun 2015 14:41 - 30 Jun 2015 14:42 #34895 by goebish
Yes, guess the H8 mini is using another protocol, is it using a xn297 as rf chip at least ?
Last edit: 30 Jun 2015 14:42 by goebish.
30 Jun 2015 14:43 #34896 by Durete
Replied by Durete on topic EAchine / Gin H7
Goebish, I guess you need also to configure the mixer as complex on aileron/pitch channels, and select "No trim" for these channels.
  • goebish
  • NRF Weirdo
30 Jun 2015 14:48 - 30 Jun 2015 14:51 #34897 by goebish
Durete wrote: Goebish, I guess you need also to configure the mixer as complex on aileron/pitch channels, and select "No trim" for these channels.
No, that's not required, I had a look at the mixer output, trims don't affect aileron & elevator channels when reassigned like I did.
Default simple mixer is fine.
Last edit: 30 Jun 2015 14:51 by goebish.
30 Jun 2015 14:52 #34898 by Durete
Ahhh, ok. Good to know. :)
30 Jun 2015 16:09 #34901 by SeByDocKy
goebish wrote: Yes, guess the H8 mini is using another protocol, is it using a xn297 as rf chip at least ?
yes
30 Jun 2015 16:17 #34905 by SeByDocKy
goebish wrote: SeByDocKy, here's how to assign trim switches to protocol trims:
I tried that and now the quad is completly crazy :( ....
I need informations about the Trim- and Trim+ respectively ...
  • goebish
  • NRF Weirdo
30 Jun 2015 16:28 #34908 by goebish
That's weird, it works perfectly on my side, here's my .ini (you may have to adapt it for 7e, for the rate switch).
Time to create page: 0.407 seconds
