SPI capture guide
- dc59
I have ordered a logic analyzer ,and want to learn SPI capture.
Where can I get some guide or manual to teach me how to do it? I don't have any experience
about this, please help.
- SeByDocKy
dc59 wrote: I ues deviation firmware for a long time and now I want to contribute something for deviation,
I did this video sometimes ago
- dc59
- greenfly
The "24Mhz" option describes the rate at which samples will be captured.
Combined, they dictate a *capture period* that you should do all your communication sampling in.
- The more samples you take the longer the capture period
- The lower the sample rate the longer the capture period
You select these in combination to give you just enough resolution you need, but with enough samples that the capture period is long enough to do all your tests. Usually 8Mhz is fast enough so 50 Million samples lets you capture about 10 seconds of activity. You can increase the sample count to extend the capture period... but the file sizes grow quickly. That's why I generally break down captures into individual small single actions.
Edit: I forgot that there is a "trigger" mechanism that can be used to make the timing a little easier. I did not learn how to use that though.
- dc59
greenfly wrote: Those describe the number of samples that will be collected during the next capture.
Thanks for your reply.
In Seby's video ,he just changed to '50 M Samples' , I didn't find he changed rate to 8Mhz , is 24Mhz ok for SPI capture ?
or I need to change it to 8Mhz?
- Durete
For TX captures, usually 8mhz is ok.
For RX captures, usually is needed more resolution. 16Mhz should be ok.
- Online
Sampling at the fastest rate possible to check the SPI clock frequency is a good place to start. Then depending on the clock frequency the sampling rate can be lowered to reduce the file size.
For some reason the SPI buses of two toy quads I've looked at have much higher SPI clock frequencies on the receiver than the transmitter.
- dc59
- Durete
hexfet wrote: Those rates should typically be okay, but the minimum rate is determined by the frequency of the SPI clock signal. To not miss any transitions in the signal being sampled the sample rate needs to be greater than the fastest transitions in the signal (for example, a square wave has transitions twice every cycle so the sample rate needs to be at least twice the square wave frequency). Haven't tested but I'd expect the SPI decoder in the logic analyzer needs to see every SPI clock transition, so the sample rate needs to be more than twice the SPI clock frequency.
Perfect explanation that I couldn't with my bad English
Hats off, Sir
- greenfly
- dc59
- dc59
~ 10MB Session data.
www.mediafire.com/download/2p3n5zzrbdm55...ni-SPI-LogicData.zip
~2.2MB Export CSV data
www.mediafire.com/download/vxue8tpbtyvuwm3/H8mini-SPI-CSV.zip
Can anyone help me to check it out and try to develop protocol?
Thanks.
- SeByDocKy
dc59 wrote: I captured Eachine H8 mini SPI data as below:
Thanks.
You should save session & data also via the top right option menu
- dc59
Thanks.
Yes, I follow your tutorial to save session&data at #1 10MB file.
- S.Giles
The 16MHz sample rate worked for me, and didn't seem to generate un-useably large files.
- robca
Trying to guess how many samples you need is super frustrating
- Durete
robca wrote: I set very longcapture times, then manually stop the process when the right events are captured... there's no need to guess how much you need, when you stop capture the Logic software saves the file until that point
Yep, me too. 100% agree
- Deal57
1. Set the SPI decoder to show HEX
2. Set the SPI analyzer settings to match the channels as you've connected them. I think your channels should be:
MOSI: 1 (maybe -- and you can always swap this later)
MISO: 0 (and you can always swap this)
Clock: 2
Enable: 3 (enable is usually configured to be active when the value is low, but you may have to play with this)
3. Use the Options to set the analyzer to show HEX data. You will also use this menu to Save the capture (useful if other people need to be able to manipulate the settings against your capture) or EXPORT data (to save off the data only). I think some of the technical guys prefer the "Save Capture" approach.
4. Set up a trigger on the ENABLE or CLOCK line. Triggers tell the analyzer to begin collecting samples at a certain point. I usually set only one channel for a trigger. In my example I used a downward change on the enable line to tell the analyzer when to begin collecting samples.
5. Once things are set up, you can move the the 0 point and see the data broken out like this:
Let me know if I can elaborate or clarify any of these notes.
- dc59
- dc59
That's a good idea, thanks!
I also follow Deal57's setting to set a trigger on clock channel,
it's perfect now.
- SPI capture guide
