Yi Zhan i6S capture
- SeByDocKy
goebish wrote: Hmmm probably a stupid question, but are you sure the module you have in your 7e can do 250Kbps ?
I tested unscrambled mode + crc with 9 byte payload on my test xn297 RX (but at 1Mbps...) and it's working fine, when I start my Devo10 with i6S protocol selected (but hacked for 1MBps...) my "rx" receives the bind packets.
Yes it's the same module for both my Devo10 & 7E. I will test the Devo10 build
- SeByDocKy
- goebish
- I Void Warranties
Can you check if other xn297 protocols are working with this version please ?
- goebish
- I Void Warranties
I'll check what's wrong.
- goebish
- I Void Warranties
Anyway, I was able to build the previous version for 7e as well, so it should be fine until I find what's wrong...
it has aileron/elevator swapped and rudder reversed.
Devo 7e
Devo 10
- SeByDocKy
goebish wrote: That's mind-blowing, I can see that the 2 versions send the same packets, with the same crc and all.... my test rx (an actual xn297) receives them, still the quads don't bind with the 2nd one...
Devo 7e
Devo 10
Ok binding fine now
AIL/ELE swap ok
Please inverse also AIL & ELE ... ( I forgot that)
Actually no extra channels are working ...
- goebish
- I Void Warranties
- goebish
- I Void Warranties
CHANNEL5 LIGHT
CHANNEL6 FLIP (not working ...)
CHANNEL7 SNAPSHOT
CHANNEL8 VIDEO
CHANNEL9 HEADLESS
Devo 7e
Devo 10
- SeByDocKy
goebish wrote: Version with extra channels, note that I couldn't find the flag in the "flip" capture, I suppose it requires a bit of throttle to work, can you make another capture for that ? (The quad doesn't need to be switched on, so you can capture at full throttle
CHANNEL5 LIGHT
CHANNEL7 SNAPSHOT
CHANNEL8 VIDEO
CHANNEL9 HEADLESS
Devo 7e
Devo 10
Everything is working
I will recapture the flip channel
- SeByDocKy
- goebish
- I Void Warranties
- SeByDocKy
- SeByDocKy
One general remark for the i6s & MT9XX. in general i use the throttle trim down to trigger camera recording. I am using the same config file with other protocols; Here, I need to keep hold down the trim button to continue the recording. There is a away to have a real latch D ?
- SeByDocKy
- goebish
- I Void Warranties
Sorry I cannot do what you want with trim button, but I think it can be done with the mixer settings no ?
(I admit I still have to read Deviation manual
- goebish
- I Void Warranties
Devo 7e
- SeByDocKy
- goebish
- I Void Warranties
God I didn't like school
- SeByDocKy
only empty one and ID = 2 are working now ...
- goebish
- I Void Warranties
Meanwhile, the code to be pushed has an hardcoded ID (just 1 byte), not a big deal unless 2 fliers want to use this protocol in the same area
- Yi Zhan i6S capture
