New FrSkyX protocol
27 Aug 2018 18:21 #70478 by hexfet
This feature will be in the next nightly build.
27 Aug 2018 19:28 #70481 by Morlacus
Replied by Morlacus on topic New FrSkyX protocol
hexfet wrote: This feature will be in the next nightly build.
Thanks a lot for the info.
Now I hope that Moeder's fix for device=xxx settings in sound.ini for the devo12s is also in the nightlies.
That will enable the use of the buzzer for the vario sound with voices for the other warnings.
Regards
29 Aug 2018 07:57 #70516 by Moeder
Replied by Moeder on topic New FrSkyX protocol
Sorry, been quite busy these weeks. I haven't pushed the fix to nightlies, please be patient a couple of days, I'll see what I can do.
29 Aug 2018 09:10 #70519 by Morlacus
Hello Moeder
Thanks for your reply. Pleased to see you again on the forum.
Regards
Morlacus
06 Sep 2018 08:06 #70679 by Morlacus
Hello
I have adjusted the Freq-Fine setting with a Frsky Rx.
I have bought another one.
Can I assume that the setting of Freq-Fine will be the same for this new Rx (and any Rx using this protocol) ?
Regards
Morlacus
12 Sep 2018 02:10 #70822 by hexfet
Probably not. My own experience is two D4R receivers with FreqFine of -42, and one XSR at -15.
12 Sep 2018 06:55 - 12 Sep 2018 06:56 #70828 by Fernandez
Replied by Fernandez on topic New FrSkyX protocol
I opened topic some time ago, to see what are the fluctuations.
I would expect that each Tx module has it's own (constant) offset.
www.deviationtx.com/forum/3-feedback-que...ncy-tunes-here#68331
Variations then would be variations in each Rx?
I believe the Midelic RX code also has some auto tune and try to bind at center? No ideaif this is also implemented in the major Rx.
Last edit: 12 Sep 2018 06:56 by Fernandez.
28 Sep 2018 16:16 #71084 by Frantico
Replied by Frantico on topic New FrSkyX protocol
Hello
I can’t bind r-xsr receiver to my jumper T8sg plus
I need some help
What I need to try?
09 Oct 2020 20:38 - 09 Oct 2020 20:45 #76868 by tomy03ful
Replied by tomy03ful on topic New FrSkyX protocol
Anyone who has a problem with binding should perform a frequency fine tuning (to go to "freq-fine" select the protocol (in this case frskyX) then press enter). It is recommended to perform it even if the default setting is correct.
The freq-fine is 0 by default, and in certain cases with frsky receivers (for example R-xsr), the freq is so bad that the binding is impossible. In some cases the binding is possible, but the connection not as good as it should be. So I recommend to do the freq fine tuning to achieve the best freq for your receiver.
Last edit: 09 Oct 2020 20:45 by tomy03ful.
17 Feb 2021 21:11 #77259 by seppilin94
Replied by seppilin94 on topic New FrSkyX protocol
I am using a Jumper T8SG Plus v2. Firmware up to date. Frsky xmplus. Tx set to FrskyX with 16ch and RSSI to LastChan. I see RSSI on the receiver tab in Betaflight on Aux12, but I can’t see the RSSI on TelemRSSI output on the Tx. Should I be doing something else?
17 Feb 2021 23:14 #77261 by Gerry
Replied by Gerry on topic New FrSkyX protocol
XM+ does not transmit rssi back to tx, only to bf for use over osd.
FFS (Forever Fixing Stuff)
22 Feb 2021 23:14 #77271 by Krejzi
Replied by Krejzi on topic New FrSkyX protocol
I just cleaned my Devo 7E from dust, because I am planning to build mu first quadcopter. Started looking at receivers, initially was planning to go with DSMX, as I know that works fine, but I started looking ad FrSkyX receivers.
I couldn't get that from that topic, but does that latest protocol supports telemetry fully ? (GPS, Voltage etc.), I can see no RSSI but what about GPS?
I want to know that before I will buy CC2500 module.
Time to create page: 0.084 seconds
