ESKY 150 V2
04 Jan 2019 22:28 #72204 by captjack01
ESKY 150 V2 was created by captjack01
Will deviation work with ESKY 150 V2 or will it require a different protocol? I tried the 2 available esky ones in 5.0 but no luck. What other protocol and module?
05 Jan 2019 00:37 #72205 by hexfet
Replied by hexfet on topic ESKY 150 V2
From the pic of the transmitter it says "compatible with Gwy ahss" on the label. Not a protocol I'm familiar with.
If you can get a pic of the label on the radio chip on the receiver or transmitter we can see if it's a supported type.
See this thread for the information needed to reverse-engineer the protocol.
If it has an FCC ID number might be able to get a little more info from the FCC website.
06 Jan 2019 22:11 - 06 Jan 2019 22:13 #72219 by captjack01
Replied by captjack01 on topic ESKY 150 V2
Actually its a blade 70s tx and has fhss transmitter on front. Supposedly its a rebranded esky 150 v2. Go figure. Is FHSS compatible with S-FHSS ?
FCCID:2ANYZ-ESKY007324 IC:23279-BLH4217 these are numbers on back of tx.
Thank you
Attachment not found
tried sending pics but wouldn't go through.
Last edit: 06 Jan 2019 22:13 by captjack01.
19 Jan 2019 18:46 #72420 by Gerhard_H
Replied by Gerhard_H on topic ESKY 150 V2
captjack01 wrote: Will deviation work with ESKY 150 V2 or will it require a different protocol?
The transmitter of the mentioned Esky heli has a chip inside which isn't part of neither Deviation nor 4in1 unit. It's a N51822.
Therefore no chance . . .
08 May 2020 17:57 #76278 by planger
Replied by planger on topic ESKY 150 V2
This protocol has now been reversed. I've used the CC2500 to emulate the N51822.
The code is available here: github.com/pascallanger/DIY-Multiprotoco...ESky150v2_cc2500.ino
Pascal
15 Jul 2020 13:06 #76590 by fin
Replied by fin on topic ESKY 150 V2
I am always grateful to Pascal. Thank you.
Will this Esky150V2 protocol ever be included in Nightly Build?
I also use OpenTx, but I'm an avid Deviation fan.
12 Aug 2020 07:04 - 12 Aug 2020 07:07 #76676 by LittleBird
Replied by LittleBird on topic ESKY 150 V2
planger wrote: This protocol has now been reversed. I've used the CC2500 to emulate the N51822.
Pascal
Hello Pascal,
I build the latest Multiprotocol with arduino 1.85 and burn to the STM32 module successful. My Tx is Taranis X9D+ with OpenTX 2.2. When I loaded the Lua, it warning "No multi module is configured". And I could not select the ESKY150V2 protocol from the "Model setup - External RF - Mode". From the selection list, it has esky and esky150, but no esky150v2.
Then I tried the precomplied FW "multi-stm-opentx-taer-inv-v1.3.1.49.bin" from the github site and the problem still remain.
I searched on google and tried many many time these two days and could not solve my problem.
Could you kindly please give me an advice?
Thank you in advance!
LittleBird
Last edit: 12 Aug 2020 07:07 by LittleBird.
06 Jun 2021 00:00 #77421 by Lumaflap
Replied by Lumaflap on topic ESKY 150 V2
Hi Everyone,
Is there any chance that the Esky 150 V2 protocol will be added some day ? It seems that planger has reversed the protocol to make it work on Deviation. It would be great, the rtf radio with the 150v2 is pure crap with an incredible deadzone and these little helis requires precision in order to fly well !
Thank you in advance !
