failsafe landing gear DEVO 12E
12 Sep 2014 07:00 - 12 Sep 2014 07:16 #25629 by cedric
failsafe landing gear DEVO 12E was created by cedric
hello, I just installed a retractable landing gear HML650 on my Tarot FY690S and I can not find how to get values ​​for failsafe in case of loss of the radio every single landing gear opens. Can you give me the process, I work as an expert on Radio mode,connected in GEAR slot Rx, GEAR switch for command
I change the values ​​of safety in the root of GEAR but I think not.
thank you in advance ;)
Last edit: 12 Sep 2014 07:16 by cedric.
13 Sep 2014 02:03 #25637 by mikemacwillie
Replied by mikemacwillie on topic failsafe landing gear DEVO 12E
Which RX are you using?
13 Sep 2014 14:17 #25641 by cedric
Replied by cedric on topic failsafe landing gear DEVO 12E
i'm use RX devo 1002
16 Sep 2014 06:13 #25690 by cedric
up, no responce?
16 Sep 2014 20:09 #25695 by mikemacwillie
On the same page as you're seeing the safety value (Channel configuration of the gear channel, under model config, then mixer), there is a fail-safe value which you can set.
17 Sep 2014 04:49 #25698 by cedric
ok i go test in the day and reply expérience
17 Sep 2014 07:00 #25699 by FDR
Replied by FDR on topic failsafe landing gear DEVO 12E
But you use the stock fw on your 12E, don't you?
AFAIK it isn't supported by deviation...
17 Sep 2014 10:44 #25700 by cedric
i use 4.0.1
17 Sep 2014 18:03 #25703 by FDR
On a DEVO 12E?
How do you do that? The 12E is not supported by deviation, is it?
17 Sep 2014 19:37 #25705 by cedric
no i in F12, my 12E receives tomorrow
17 Sep 2014 20:32 #25706 by hexfet
Replied by hexfet on topic failsafe landing gear DEVO 12E
Does the RX1002 have a failsafe feature? (I thought it does not)
17 Sep 2014 20:35 #25707 by cedric
I know that's why I ask. I saw a video for the retractable landing gear that had one but I think it was on fubata.
18 Sep 2014 15:33 #25720 by FDR
hexfet wrote: Does the RX1002 have a failsafe feature? (I thought it does not)
AFAIK all DEVO receivers have the fail-safe feature...
18 Sep 2014 15:34 #25721 by mikemacwillie
That's my understanding as well, but I only have experience with the RX1202.
20 Sep 2014 02:04 #25743 by hexfet
Just received my first servos and tried it out. The RX1002 does indeed support failsafe. Not mentioned in the Walkera documentation...
20 Sep 2014 08:07 - 20 Sep 2014 14:39 #25744 by cedric
Grrrr.... dommage
i receved my F12E whit rx1202 white,failsafe it's ok in this Rx?
Last edit: 20 Sep 2014 14:39 by cedric.
21 Sep 2014 15:12 #25754 by mikemacwillie
Yep, should be the same as the black one.
