Devo f12 stock firmware
- Wesley_1978
- Topic Author
06 Dec 2015 07:44 #40620
by Wesley_1978
Devo f12 stock firmware was created by Wesley_1978
I hope to find help here....
I buyed a walkera devo f12 without receiver.
I wanted to bind the transmitter with a spektrum
receiver but it wouldend work. After reading around
i tought it would after a firmware upgrade from
the section "nightly builds". It did not work.
I only have white screens now. Alsow in the
software upgrade menu. Tryed all different firmwares
but nothing works. Is there anyone who knows wat to do?
The original firmware maby but i dont find it anyware.
Please help :-/
Please help :-/
06 Dec 2015 08:18 - 06 Dec 2015 20:40 #40621
You can only bind DEVO receivers with the stock fw, which you can download from here:
walkera-fans.de/download/sender/devo_f12...20Firmware%201.5.zip
However if you use this deviation upload tool to install the nightly build, it should properly install deviation on it:
deviationtx.com/downloads-new/category/1...ation-uploader-0-8-0
Replied by FDR on topic Devo f12 stock firmware
Last edit: 06 Dec 2015 20:40 by FDR.
- Wesley_1978
- Topic Author
06 Dec 2015 08:57 #40622
by Wesley_1978
Replied by Wesley_1978 on topic Devo f12 stock firmware
Hi FDR,
Thx for replying.
I cant open the last file, wat program do i need for it?
And how do i proceed now to do it wright?
Thx for replying.
06 Dec 2015 11:08 #40625
That is a Java jar file, you need a Java Runtime Engine (JRE) from Oracle to run that...
- Wesley_1978
- Topic Author
06 Dec 2015 11:36 #40626
by Wesley_1978
ok, got the program running but it cant see the transmitter
06 Dec 2015 12:56 - 06 Dec 2015 12:57 #40628
Replied by vlad_vy on topic Devo f12 stock firmware
If radio is Devo F12, it doesn't help. Deviation has not support for Devo F12, but for Devo F12E.
Last edit: 06 Dec 2015 12:57 by vlad_vy.
- Wesley_1978
- Topic Author
06 Dec 2015 12:59 #40629
by Wesley_1978
So wat to do now? Trow it away? :-/
06 Dec 2015 16:08 #40631
Oops, sorry, I misread your port, and was thinking about the F12E, which is quite popular nowadays.
The F12 is not supported by deviation, and I don't know if anybody has it's original fw.
Try to contact Walkera and ask for a fw for it.
- sm3hurk0
25 Dec 2015 02:35 #41128
by sm3hurk0
Replied by sm3hurk0 on topic Devo f12 stock firmware
I have a transmitter Devo F12. Can I make him a backup and give you a file.
A year ago, I can flash my other radio (DEVO 12S). I do not remember in the software (Devo_flash_tool_DfuSe V2.0 ), if there was an option to backup transmitter.
Excuse me for bad English.
25 Dec 2015 19:01 #41134
No, the fw memory is read protected.
Time to create page: 0.036 seconds
- Home
- General
- Stock Firmware Help
- Devo f12 stock firmware
