Devo 7e battery voltage calibration issue
- jim
- Topic Author
03 Sep 2016 00:29 #53428
by jim
Devo 7e battery voltage calibration issue was created by jim
On my Devo 7e the voltage reported by the firmware is never the correct voltage (its always a good bit lower than the actual voltage that I measure with my trusty volt meter).
Due to this it keep thinking it's running out of juice after like 10min of use. Is there a way to calibrate it, or should i just find the "right" low voltage alarm that corresponding to real-life low voltage that I measure as a work-around?
Is it also possible that I need to supply more voltage (I use 1.2v eneloops so its lower voltage than "stock"), or use/solder an additional regulator?
thx
thx
- HappyHarry
03 Sep 2016 00:32 #53430
by HappyHarry
Replied by HappyHarry on topic Devo 7e battery voltage calibration issue
when you say a 'good bit lower' how much are we talking?
- jim
- Topic Author
03 Sep 2016 00:46 #53432
by jim
Replied by jim on topic Devo 7e battery voltage calibration issue
about 0.5v (it jumps around a bit)
it doesn't seem to be linear which bothers me most...
real voltage - devo voltage
4.8v - 4.4v
4.6v - 3.9v (starts complaining about low voltage)
This somehow seem to be more of a problem when using the FrSkyX protocol (has telemetry/consumes more probably) rather than DSM2 though I'm not sure if that makes a diff.
4.8v - 4.4v
Time to create page: 0.031 seconds
- Home
- General
- Stock Firmware Help
- Devo 7e battery voltage calibration issue
