Can't Bind RX1002 with DEVO F12E TX
14 Jan 2017 11:34 #57933 by maianunes
Can't Bind RX1002 with DEVO F12E TX was created by maianunes
Recently I bougth two RX1002 for my DIY drones.
One I bind it with no issues using the procedure:
- Put Bind Plug in BAT of the RX
- Power ON RX (Red Led light's slowly)
- Power OFF RX and remove the Bind Plug
- Power ON RX (Red Led light's fast)
- Power ON TX F12E with Fixed ID (OFF)
- Red Led on RX turns solid (bind complete)
The Second Receiver RX1002 does the following:
- Red Led on RX keeps flashing fast (no bind)
I've tried several combinations of this procedure but nothing Works.
Do you have some idias to help me? Thank you
14 Jan 2017 15:24 #57939 by FDR
Replied by FDR on topic Can't Bind RX1002 with DEVO F12E TX
Once you cleared the fixed id from the rx, there is no more need to use the bind plug, it is actually only for unbinding.
Simply turn on the tx with cleared fixed id, and within 10 seconds turn on the rx.
After this auto bind, you can set a fixed id and then send it to the rx with the bind button.
Next time you can turn them on in any order without any time limit and they will still be bound.
14 Jan 2017 16:21 #57940 by maianunes
Replied by maianunes on topic Can't Bind RX1002 with DEVO F12E TX
Thank you for your advice but that's what I did with no sucess.
The Red Led does not go solid. It keep's flashing quickly. No bind.
It's very strange, the Rx seems to work fine until the binding part.
14 Jan 2017 19:43 #57945 by FDR
If it flashes quickly it means there is a fixed id stored in it.
You need to clear it first with a bind plug, but without the tx.
Plug in the bind plug, connect the battery, wait for slow flashes, unplug the battery and the bind plug.
14 Jan 2017 21:02 #57948 by maianunes
I did all that like I said in the first post, but the problem remains:
- Put Bind Plug in BAT of the RX, Power ON RX (Red Led light's slowly) = cleared fixed id
- Power ON RX (Red Led light's quickly)
- Red Led continue to flash quickly, never bind
I don't have more ideas.
Can the receiver his faulty? it's brand new...
14 Jan 2017 21:11 #57949 by FDR
How quickly does it flash?
If it has fixed id it is very quick, but during the auto bind it is medium, about twice in a second.
Have you let it flash slowly at least three times during the fixed id clearing?
What do you mean on "Fixed ID (OFF)"? Have you cleared the fixed id value, so it shows "None" in the box?
14 Jan 2017 21:26 #57953 by maianunes
1º - I'm not certain but I would say about twice per second
2º - Yes, I let it slowly flash for about 1/2 minute (just did it again to be sure, but the result is the same)
3º - In the F12E menus I did the following:
- Model Menu - Fixed ID - Status Off
Then I power OFF the transmitter and back ON to bind
15 Jan 2017 12:10 #57964 by FDR
I searched for a F12E emulator.
The Fixed ID box should look like this, i.e. showing "None" if you deleted the ID:
15 Jan 2017 12:57 #57966 by maianunes
Sorry but I don't have that menu in my transmitter.
What I have is the menus in the attached photos.
So I don't have any way to know if the Fixed ID is really NONE.
15 Jan 2017 12:59 #57967 by maianunes
Forgot to mention that my Firmware is:
Hardware Ver. 1.2
Software Ver. 1.5A
15 Jan 2017 13:08 #57968 by vlad_vy
Replied by vlad_vy on topic Can't Bind RX1002 with DEVO F12E TX
For original firmware Fixed ID = OFF equal to NONE for Deviation firmware.
Try to power on Rx with battery plug reversed to BAT (without bind plug at all), sometimes it helps to clear Rx Fixed ID.
15 Jan 2017 14:02 #57975 by maianunes
Done, but the problem remains, although the RX red LED starts to flash slowly as if he had the bind Plug connected
15 Jan 2017 18:34 #57993 by FDR
Sorry, I didn't know that you are using the stock firmware...
15 Jan 2017 19:02 #57994 by maianunes
I've tried to install several Firmwares from deVention (Nightly Builds) but it was stuck all the time after flashing with a message USB "something" I don't recall.
Any way I don't think the Binding problem of this receiver is not the transmitter because it works fine with all the other receivers
15 Jan 2017 19:57 #57996 by maianunes
I've just tried to upgrade the latest deVention Firmware on F12E but it gave me the same error (attached photo).
20170115 deviation-devof12e-v5.0.0-f590316
15 Jan 2017 20:17 #57997 by SirDomsen
Replied by SirDomsen on topic Can't Bind RX1002 with DEVO F12E TX
Well it's Deviation, not deVention.
Anyway: Now you need to,put the file system on your tx. Should show up as an USB flash drive while connected. Then just copy the files on it (or is it devo.fs for F12e also?). should be contained in the deviation .zip file.
15 Jan 2017 20:56 #58000 by maianunes
You are right. I already reinstall the 1.5A firmware.
Can you send me a link to download the latest DEVENTION firmware to F12E ?
23 Jan 2017 01:42 #58310 by Artus
Replied by Artus on topic Can't Bind RX1002 with DEVO F12E TX
If you copy the devo.fs file from your pc via USB to your f12e deviation starts your tx
I had the same problem after installing deviation but now I am able to work with
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
23 Jan 2017 07:57 #58312 by maianunes
Thank you for your tip, but unfortunately when I connect the F12E to the PC (USB) normal mode, or in DFU mode, it doesn't appear in the PC explorer devices, although it appears in MANAGE DEVICE / USB CONTROLLERS / STM Device in DFU Mode
How did you copy the devo.fs to the F12E ?
23 Jan 2017 15:31 - 23 Jan 2017 15:33 #58322 by Artus
Ok try this:
Download usb-driver changer (this one which changes from Walkara-Dfuse mode to Deviaton-downloader mode.
Restart every time your PC after changing drivers.
And Install Deviaton with all "enabled".
The f12E in usb mode must be detected as a small usb-drive.
You cant damage - you always can go back to the Walkera-firmware
If the F12E - drive is not detected - there is something wrong with your PC.
I will try to guide your installation - i have done 2 weeks ago - and after 2 nights its running :)
Last edit: 23 Jan 2017 15:33 by Artus.
Time to create page: 0.171 seconds
