DEVO 10 - I want original devo firmware back!
- cnumb
- Topic Author
I've already have an other Devo10 with original firmware and a lot of model profiles.
I've done everything, but finally there are two possibilities: 1.) with or without formatting memory card, it is impossible to setup devo 10 firmware 0.7 + Lib 2, that is, the result is that there are black or unreadable symbols on screen. 2.) devention 5 setup is always succesful and fully fubctional.
I use dfuse usb upgrade tools 2.31 and a direct usb cable with PC.
Thanks, ind advance
Reinstalling both the library & dfu file for the original software with 2.31 should do the trick. I've not done it with a 10, but it worked fine for a 6. So either 1) the hardware has been modded in a way that makes it incompatible with devention, or 2) you're doing something wrong.
For 1, check with whoever you bought it from.
For 2, provide a detailed list of the steps you took to install the devention dfu & library. The more detail, the better.
- cnumb
- Topic Author
I've read all available infos.
The situation is the following:
1. TX memory -as a drive- can be seen only when deviation firmware is installed. If so, I can format that memory as a "drive".
2. Other ways I can connect TX to pc only as a DFU device. I use devention DfuSe Upgrade tool 2.31. This way, I can setup .dfu files, either DEVO-10 Fw v0.7A.dfu or deviation-devo10-v5.0.0.dfu, regarding which firmware I choose.
3. When installing deviation 5, in SECOND STEP, I use USB connection and copy all files and folders from template (language, layout,... etc.) When finished, TX works well with devention 5.
4. When installing devention 0.7, I can only use DfuSe Upgrade Tool to upgrade DEVO-10 Lib v0.2.dfu file. In this case I have no direct connection to TX memory (as a drive) so that I cant load any other file.
So, something is going wrong: upgrading TX as a DFU device, using DeFuse Upgrade Tool 2.31 with these files leads to an abnormal state.
Upload ruins the dfu file, so you need a fresh copy of it first...
- cnumb
- Topic Author
- cnumb
- Topic Author
- jfitz66
Big Thank yous in advance!!!!
- jfitz66
- jfitz66
All the info is on this page .
- pezza2
I'm new to this forum , I have 6 x Devo10 transmitters ,I have tried to use use use the dfuse 2.31 upgrade tool on all of them but it isn't recognized on any of them. I'm using windows10. I have followed all instructions regarding connection but still no luck.
Can any one help , please?
- jfitz66
- pezza2
When I did this awhile back something went wrong and the screen was unusable , file must have been corrupted.
All good now thanks for your response
- otterslide
I flashed every possible FW Version, followed by Lib at the same time. FW 0.4 with Lib 0.1 , FW 0.6 with Lib 0.1, and FW 0.8A with Lib 0.2,
and it never boots. Tried multiple times, and then press "Leave FDU Mode" , with DFuse 2.3 .
Every time I click leave, it shows a screen that says "Devention Version Error" and keeps rebooting. Remove battery, plug back, same thing.
With 0.6 it says "Model Select" and keeps rebooting instead of Version Error.
I installed DeviationTX 5.0.0 DFU back and copied filesystem, and it's working again, but how can I get stock firmware back?
It is a Devo 10, I wonder what this "Version Error" means?
- -=Hubi-Dirk=-
walkera-fans.de/downloads/
walkera-fans.de/walkera-update-anleitungen/
If necessary, you can have the sites translated:
translate.google.com/?sl=auto&tl=de&op=websites
- otterslide
Click Leave DFU, it restarts, but does not boot.
That's the "upgrade" procedure. I wonder if going from Deviation to Devention is the same procedure. Maybe I need to clear out some Deviation files first?
The firmware and library get uploaded, but that's not good enough. But the Deviation DFU works fine, so that confirms the "upgrade" button is actually working.
- jfitz66
- otterslide
jfitz66 wrote: Its been a long time but I seem to recall the procedures are not the same for Devention and Deviation. I can't remember the details but pretty sure I caught a post about that somewhere in this thread.
Deviation requires flashing the FW first, then reboot and plug in, then formatting the drive and then copying the filesystem files.
Devention as far as I know, requires flashing the FW and Lib files one after the other,.. this is what I'm doing anyway, and it's not working.
- Home
- General
- Stock Firmware Help
- DEVO 10 - I want original devo firmware back!
