Display resolution problem T8sg V2 Plus
- Quemelias
- Topic Author
13 Oct 2019 20:00 #75245
by Quemelias
Display resolution problem T8sg V2 Plus was created by Quemelias
14 Oct 2019 03:45 #75246
Replied by vlad_vy on topic Display resolution problem T8sg V2 Plus
What firmware? It looks like Jumper changed LCD,since LCD has to be yellow.
- Quemelias
- Topic Author
14 Oct 2019 08:22 #75250
by Quemelias
Replied by Quemelias on topic Display resolution problem T8sg V2 Plus
The firmware is deviation-t8sg_v2_plus-v5.0.0-28ce50f. First use Dfuse Usb to enter the file .dfu. Then in USB mode, I introduced the files. It´s the carbon mode T8sg V2 plus. It is the first time I use this type of station and the seller does not know how to give me a solution. Thanx
14 Oct 2019 09:38 #75253
You can try different build, but I think it doesn't help:
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
- Quemelias
- Topic Author
14 Oct 2019 13:54 #75255
by Quemelias
I have tried and the failure continues. Thanks for the help!!!
- Vasilisf7
25 Oct 2019 00:31 #75312
by Vasilisf7
Replied by Vasilisf7 on topic Display resolution problem T8sg V2 Plus
Flash a firmware for a T8SG V2.0 not the plus version.
I had to contact jumper to figure it out.
This is what they did.
They made a jumper T8SG V2.0 plus carbon with lcd screen and a v3.0 board but it is not compatible with the plus version firmware in deviation tx.
- Quemelias
- Topic Author
31 Oct 2019 21:15 #75355
by Quemelias
I try it and tell you how it went. Thanx
- Quemelias
- Topic Author
04 Dec 2019 20:22 #75520
by Quemelias
That firmware does not work. I'm going to ask for an opinion on Jumper. I will inform
- pepitoria
03 Apr 2020 16:56 #76133
by pepitoria
Replied by pepitoria on topic Display resolution problem T8sg V2 Plus
I am having the same issue. Did you manage to fix it?
- cerox
15 May 2020 18:02 #76319
by cerox
Replied by cerox on topic Display resolution problem T8sg V2 Plus
Same for me... When I install firmware for V2 (not plus). The screen remains black. I think I have a T8SG V3 plus with oled display. Is it possible ?
- Vasilisf7
15 May 2020 18:10 #76320
by Vasilisf7
Flash the firmware that dosen't say plus
- cerox
15 May 2020 18:51 #76321
by cerox
I just installed deviation-t8sg_v2-v5.0.0-5efb6a2 and when I turn it on the screen remains black. Don't know what to do...
Time to create page: 0.079 seconds
- Home
- General
- Stock Firmware Help
- Display resolution problem T8sg V2 Plus
