T8SG+ DFUse upgrade tool wrong driver *SOLVED*
- Matthewdupreez
- Topic Author
13 May 2023 09:30 - 14 May 2023 15:33 #78256
by Matthewdupreez
T8SG+ DFUse upgrade tool wrong driver *SOLVED* was created by Matthewdupreez
hey guys i have a Jumper T8sg plus that recently started showing me the USB icon on the screen, running deviation tx,
now i cannot seem to get my laptop to load the correct driver for me to either reflash the firmware. when the tx is in DFU mode, or to open and replace the files when it's in usb mode.
does anyone perhaps have the link for it? i'm running windows 10.
please help this is rather urgent.
Regards Matthew
PROBLEM SOLVED.
what any instructions forget to tell you is that there is a procedure to get it to work properly while bricked in usb mode.
it is as follows
turn off tx
plug tx into pc
turn on tx
vooila pc opens it's folders and allows me to format it and replace folders...
it does not work if it is turned on before plugged in...
sounds stupid. but if you don't think about it.... yea you pull your hair out
Regards Matthew
PROBLEM SOLVED.
it is as follows
turn off tx
plug tx into pc
turn on tx
Last edit: 14 May 2023 15:33 by Matthewdupreez.
- Matthewdupreez
- Topic Author
13 May 2023 10:14 #78257
by Matthewdupreez
Replied by Matthewdupreez on topic T8SG+ DFUse upgrade tool wrong driver HELP!!!!!!!!
alright so i managed to get the right DFU driver nd have now updated the firmware on the tx, however i cannot seen to now open the file of the radio while in usb mode to replace all it's files with new ones.
as it is still only booting up into usb mode
could any of you please try share the driver name that works for you?
- Matthewdupreez
- Topic Author
14 May 2023 15:32 #78258
by Matthewdupreez
PROBLEM SOLVED.
it is as follows
turn off tx
plug tx into pc
turn on tx
Matthewdupreez wrote: hey guys i have a Jumper T8sg plus that recently started showing me the USB icon on the screen, running deviation tx,
Regards Matthew
PROBLEM SOLVED.
it is as follows
turn off tx
plug tx into pc
turn on tx
Time to create page: 0.030 seconds
- Home
- General
- Stock Firmware Help
- T8SG+ DFUse upgrade tool wrong driver *SOLVED*
