User Tools
Site Tools
model_config:align_t-rex_150_dfc_-_3_difficulty_modes
Align T-Rex 150 DFC - 3 Difficulty Modes
I made this model based off my other Align T-Rex 150 DFC models.
It has 3 difficulty modes: Beginner, Standard, 3D. The difficulty modes are controlled with the Flight Mode Switch.
Normal - Beginner Settings
No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
D/R = 50% EXP +30%
ST-1 - Standard Settings
-3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
D/R = 70% EXP +30%
ST-2 - 3D Settings
Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
D/R = 125% EXP LIN
Model 48 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
  • Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Set your ESC Li-po Cell Count setting to “AUTO”. Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to “Auto”.
Do not use the “2S” setting. You will have an extreme power/headspeed loss using the default “2S” setting.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: More aggressive V Shaped Throttle Curve
Pitch Curve
Normal: No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
ST-1: -3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
ST-2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
DR/EXPO is controlled with the Flight Mode Switch.
Normal: Beginner Settings
ELEV D/R = 50% EXP +30%
AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP +15%
ST-1: Standard Settings
ELEV D/R = 70% EXP +30%
AILE D/R = 70% EXP +30%
ST-2: 3D Settings
ELEV D/R = 125% EXP LIN
AILE D/R = 125% EXP LIN
RUDD D/R = 100% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model48_2014-04-30
model_config/align_t-rex_150_dfc_-_3_difficulty_modes.txt (47567 views) · Last modified: 2014/04/30 19:03 by Tom Z
