User Tools
Site Tools
model_config:align_t-rex_150_dfc_-_beginner_settings
Align T-Rex 150 DFC - Beginner Settings
This model is for use with the Spektrum DSM2/DSMX Satellite Receiver.
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
  • Lower Pitch Travel Adjustment to make the heli tamer * Low dual rates and positive expo to tame the heli down * Throttle hold on the RUDD D/R switch * 7 Point Throttle and Pitch Curves * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 20 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 20-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 20 instead.
Set your ESC Li-po Cell Count setting to “AUTO”. Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to “Auto”.
Do not use the “2S” setting. You will have an extreme power/headspeed loss using the default “2S” setting.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
NORM - 0% 30% 50% 55% 60%
ST- 1 - 70% 68% 65% 68% 70%
ST- 2 - 80% 77% 74% 77% 80%
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP +15%
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model20_2014-02-23
model20-2_2014-02-23
model_config/align_t-rex_150_dfc_-_beginner_settings.txt (153351 views) · Last modified: 2014/01/10 09:03 by Tom Z
