User Tools
Site Tools
model_config:align_t-rex_150_dfc_-_standard_settings
Align T-Rex 150 DFC - Standard Settings
This model is for use with the Spektrum DSM2/DSMX Satellite Receiver.
  • 7 Point Throttle and Pitch Curves * Throttle hold on the RUDD D/R switch * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 21 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 21-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 21 instead.
Set your ESC Li-po Cell Count setting to “AUTO”. Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to “Auto”.
Do not use the “2S” setting. You will have an extreme power/headspeed loss using the default “2S” setting.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
NORM - 0% 30% 50% 55% 60%
ST- 1 - 90% 86% 84% 86% 90%
ST- 2 - 90% 86% 84% 86% 90%
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP +15%
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model21_2014-02-23
model21-2_2014-02-23
model_config/align_t-rex_150_dfc_-_standard_settings.txt (63032 views) · Last modified: 2014/01/10 09:06 by Tom Z
