User Tools
Site Tools
model_config:blade_130_x_-_3d_settings
Blade 130 X - 3D Settings
  • Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 36 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 36-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 36 instead.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
Normal: 0% 40% 60% 68% 75%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model36-2
model36_2014-01-26
model_config/blade_130_x_-_3d_settings.txt (33296 views) · Last modified: 2014/01/26 09:06 by Tom Z
