User Tools
Site Tools
model_config:blade_180_qx_hd
Blade 180 QX HD
This model was made by kreidler. http://deviationtx.com/forum/model-configs/2561-blade-180-qx#18088
I added DR/EXPO functions and added my custom GUI which also includes
Battery and TxPower to the b/w screens.
Model 37 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
The Devo 7e only has two flight modes FMOD0 and FMOD1 and this model is made for three flight modes: FMOD0 - FMOD1 - FMOD2
The flight mode switches between Stability mode with low flight angles, Stability mode with high flight angles, and Agility mode.
kreidler has a model for the Devo 7e with a 3 switch mod.
  • Throttle hold on the RUDD D/R switch. * TX Power=100mW * Channels=6 * Protocol=DSMX * No Fixed ID * Model Type=Plane * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
The Blade 180 QX HD owners manual has these settings below for High Rate/Low Rate listed for all these transmitters: DX6i, DX7/7SE, DX7S, DX8, DX9/DX18
They do not list any Expo settings.
You can add EXPO if you want. I suggest +30% as a starting point and adjust it up or down from there.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP LIN
0- AILE D/R = 70% EXP LIN
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Turn up RUD Scale -/+ to 150 if you want faster piros.
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model37_2014-01-27
model_config/blade_180_qx_hd.txt (21528 views) · Last modified: 2014/01/27 16:49 by Tom Z
