model_config:blade_350_qx_rth_problem_with_devo_7_e
blade 350 qx RTH problem with devo 7 e
hi
i have a problem with my blade 350, when i flying goes in return to home mode, and a little seconds later changes in the normal mode, smart or stability mode is the same…. i have the devo 7e with the 2 switch mods, and the actually nightly build….
you are have the same problems?? or another model config, i have added the .ini file
thx
model_config/blade_350_qx_rth_problem_with_devo_7_e.txt (64653 views) · Last modified: 2014/03/15 10:33 by southtirol32
