User Tools
Site Tools
model_config:blade_fp_helicopter_-_beginner_settings
Blade FP Helicopter - Beginner Settings
This model will work on the following helicopters.
  • Blade SR 120 * Blade mSR/mSR-X * Blade mCX/mCX2 * Low dual rates and positive expo to tame the heli down. * Throttle hold on the RUDD D/R switch. * TX Power=100mW * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 25 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Flight Mode switch on “0” = Helicopter will be tamer, soft throttle response
Flight Mode switch on “1” = More responsive, normal throttle response
Flight Mode switch on “2” = More responsive, normal throttle response
Channel 5 affects rate settings of the 5-in-1 Control Unit.
Use the Gear switch to switch between high and low rate.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model25_2014-01-24
model_config/blade_fp_helicopter_-_beginner_settings.txt (108102 views) · Last modified: 2014/01/13 17:08 by Tom Z
