User Tools
Site Tools
model_config:blade_mqx
Blade mQX
  • Throttle hold on the RUDD D/R switch * TX Power=100mW * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 19 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Flight Mode controls the response.
  • Flight Mode 1 = Beginner Settings * Flight Mode 2 = Standard Settings * Flight Mode 3 = Aggressive Settings
Turn up RUD Scale -/+ to 150 if you want faster piros.
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model19
model_config/blade_mqx.txt (50964 views) · Last modified: 2014/01/08 17:13 by Tom Z
