User Tools
Site Tools
model_config:blade_nano_cpx_mcpx_130x_-_3_difficulty_modes
Blade Nano CPX/mCPX/130X - 3 Difficulty Modes
I made this model based off my other Blade models.
It has 3 difficulty modes: Beginner, Standard, 3D. The difficulty modes are controlled with the Flight Mode Switch.
This model is for the Blade Nano CPX/mCPX BL.
There are models below this post for the Blade 130X and Blade mCPX V1/V2.
Normal - Beginner Settings
No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
D/R = 50% EXP +30%
ST-1 - Standard Settings
-3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
D/R = 70% EXP +30%
ST-2 - 3D Settings
Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
D/R = 125% EXP LIN
Model 49 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
  • Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
ST-1: -3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
ST-2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
DR/EXPO
DR/EXPO is controlled with the Flight Mode Switch.
Normal: Beginner Settings
ELEV D/R = 50% EXP +30%
AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
ST-1: Standard Settings
ELEV D/R = 70% EXP +30%
AILE D/R = 70% EXP +30%
ST-2: 3D Settings
ELEV D/R = 125% EXP LIN
AILE D/R = 125% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model49_2014-04-30
model_config/blade_nano_cpx_mcpx_130x_-_3_difficulty_modes.txt (84817 views) · Last modified: 2014/04/30 21:33 by Tom Z
