User Tools
Site Tools
model_config:blade_nano_qx
Blade Nano QX
This model was made by fabien for the Devo 8 with Deviation v3.0
I converted the v3 model to v4 and added my custom GUI layout which will work on all these transmitters: DEVO 6/6S/8/8S/10/12/12S.
* This model will work on the Devo 7e but due to there is one less flight mode on that model you will not have all three flight modes FMOD0 - FMOD1 - FMOD2.
You will only have FMOD0 - FMOD1.
FMOD0: Stability mode
FMOD1: Agility mode/ 70% dual rate
FMOD2: Agility mode/ 100% dual rate
The v4 model was test flow by Syrabane.
http://deviationtx.com/forum/6-general-discussions/2644-hey-guys-seeking-help-with-my-devo-10#18793
model15_2014-01-20_2014-01-20
Here is the post by fabien for his v3 model if you want to see his settings he used or download the model for v3.
http://deviationtx.com/forum/model-configs/1933-nano-qx-from-horizon?start=20#12197
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model_config/blade_nano_qx.txt (69016 views) · Last modified: 2014/01/20 13:49 by Tom Z
