User Tools
Site Tools
model_config:blade_walkera_align_-_standard_mixer
Blade/Walkera/Align - Standard Mixer
I just made some models from scratch using the Standard Mixer.
One model is for the Devo 7e only.
The other model is for the following transmitters: DEVO 6/6S/8/8S/10/12/12S
The Blade CP models I recommend you adjust the Throttle Curves, Pitch Curves, DR/EXPO, and Pitch Travel (only for some models) according to what model Blade CP helicopter you have.
The model can be installed and flown as it is but it is better to fine tune the model for the model you have.
The Walkera CP helicopters models are ready to install and fly.
Customize the settings to what you like.
The Align T-Rex 150 DFC model is ready to install and fly.
I have models made with the Standard Mixer that will work for the following helicopters:
Blade
  • Blade Nano CPX * Blade mCPX V1/V2/BL * Blade 130X
Walkera
  • Walkera V120D02S * Walkera V120D02S V2 * Walkera Mini CP * Walkera Super CP * Walkera Genius CP V1/V2 * Walkera V100D08
[li]Walkera Master CP
[li]Walkera V450D01/D03
The model will work in the Walkera 4f200lm but you need to reverse ALIE and RUDD.
The model will work in the Walkera V200D03 but you need to reverse ELEV and RUDD.
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Align
Align T-Rex 150 DFC
If you would like Beginner or 3D settings you can use the model as a starting point and use my settings from my Tx Setup Guides on my web site: http://www.rcproreviews.com
I made the model in the Standard Mixer which is easy to change the settings and is similar to the menus and options we are use to.
I made all my models in the Advanced Mixer due to the Standard Mixer doesn't have all the features and options I needed.
I wanted to offer my model in the Standard Mixer format to help out the people who are having problems with the Advanced Mixer format due to it is completely different than the menus and options people are use to.
* I will not be making any more models made in the Standard Mixer.
The models are for the Deviation V4 Firmware only.
Blade CP Helicopters and the DEVO 6/6S/8/8S/10/12/12S.
modelbcp
Blade CP Helicopters and the Devo 7e only.
modelbcp_devo7e
Align T-Rex 150 DFC and the DEVO 6/6S/8/8S/10/12/12S.
model21-3_2014-02-17-2
Align T-Rex 150 DFC and the Devo 7e only.
model21-3_devo7e
Walkera CP helicopters and the DEVO 6/6S/8/8S/10/12/12S.
model8-3_2014-02-17
Walkera CP helicopters and the Devo 7e only.
model8-3_devo7e
model_config/blade_walkera_align_-_standard_mixer.txt (76861 views) · Last modified: 2014/02/17 11:35 by Tom Z
