User Tools
Site Tools
model_config:devo_10_for_fx071_with_6g_3g_and_3_flight_modes
Devo 10 for FX071 with 6G / 3G and 3 flight modes
okay here it is the official kiwi-craig FX 071 Devo 10 flight model Version 1
this has three flight modes, three tail modes, 6g AND 3G ! decent icons loaded against the toggle switches and a 5 point throttle curve, and a custom screen icon.
how it all works
throttle hold on DR 1 , TH icons used on the display
Dual Rates on Gear switch, Gear 1 = reduced rate, DR icons uses on display
Mix 0 = 6G mode Mix 1 = 3G mode, G icons used
yes they have a 3G mode in there ! be warned it's crazy but flyable, with my three flight mode setup heck I was flying it in the lounge on the tame mode ! and that was the whole point of having the three flights setup in this.
Fmode = the kiwi magic you now have three flight modes; this uses a modified version of the Florida Heli setup for the V930
FMODE 0 = Tame, M0 on the display
FMODE 1 = Normal, M1 on the display
FMODE 2 = Agile, M2 on the display
FMODE is also linked to 6G - 3G switch. you get more servo travel in 3G mode :evil:
Tail is tied to the FMODE and has three differing setups
FMODE 0 tail is 1 to 1 and scalar 80
FMODE 1 tail is expo 10% scalar 100
FMODE 2 tail is expo 20% scalar 120 not sure how effective the 120% will be but its int there for now.
throttle curve is a 5 point, currently linear -100,-50,0,50,100 but easy to change to whatever you like
this is experimental but all works as planned.
also has a custom icon, copy the FX071.bmp into the devo file folder marked modelico
all care, no responsibility
would really like some flight testers and feedback on settings. I can change switch settings if someone wants a different layout.
this can also be used on the FX076, 070 and 067 I will be testing it on the 067 soon.
model28
model_config/devo_10_for_fx071_with_6g_3g_and_3_flight_modes.txt (60006 views) · Last modified: 2016/03/18 16:05 by kiwi-craig
