User Tools
Site Tools
model_config:flip_fpv_quadcopter
Flip FPV Quadcopter
This model was made by Rambosmurf which sent me the model.
I converted it to the V4 firmware and added my custom GUI.
Edit: 2-18-2014
The model has been updated. The new model name is Model1_FlipFPV_V2
The Quad is running the Crius AIOP V2 Board with GPS and MegapiratesNG software.
Flight Modes when using Mission Planner are:
FMode 0 = Stab - Self Correcting Flight
FMode 1 = Acro - Full 3D Controls
FMode 2 = Loiter - GPS Lock and Altitude Hold
Mix 0 = Nothing - Stab Mode Default
Mix 1 = Alt Hold - Non Gps Hold
Mix 2 = RTL - Return to Launch
Gear = Land - Lands at present location
Channel 6 is connected to Aux 5 which can be used to do tuning via Mission planner. Channel 7 is set-up for extra use of servo for camera gimbals or other options.
The model is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
* The model will not work for deviation firmware v2.1 or v3.
model1_flipfpv_v2
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model_config/flip_fpv_quadcopter.txt (60497 views) · Last modified: 2014/02/17 22:15 by Tom Z
